Old 06-24-2003, 09:09 PM   #1
tmad
Quick ? please respond
Im finally putting my 1967 2wd lb back together. My question is this, On a 67 should the front parking lights stay on when the headlights are pulled on? And if so what would cause mine to go off when I pull switch all the way out???
tmad is offline   Reply With Quote
Old 06-24-2003, 09:12 PM   #2
Wabash
Wabash's Avatar
yes they should stay on after the switch is pulled out.
do the go out even when you pull the switch half way out to just run the parking lights??
1972 C/10 LWB
1972 K/5 Blazer
Wabash is offline   Reply With Quote
Old 06-24-2003, 09:17 PM   #3
tmad
No if I pull just out for parking lights they work fine when I pull all the way out for headlights the headlights come on but the parking lights go off. and if i try the turn signals with the headlights on they seem to blink real fast????
Old 06-24-2003, 09:37 PM   #4
pickup6772
pickup6772's Avatar
TMAD, THEY SHOULD GO OFF WHEN THE HEADLIGHTS ARE ON. THE PARKING LIGHTS DID NOT STAY ON WITH THE HEADLIGHT UNTIL THE ADDITION OF SIDEMARKER LIGHTS (1968). I HAVE WHAT I BELIEVE IS A "LATE" '67 THAT HAD "DUMMY" LIGHTS IN THE FRONT FENDERS. I'M NOT THE ORIGINAL OWNER OF THIS TRUCK, SO FOR ALL I KNOW, THE FENDERS COULD HAVE BEEN REPLACED WITH '68'S. I REPLACED THE LIGHTING HARNESS WITH ONE FROM A '69, AND PUT IN "REAL" SIDEMARKER LENSES. NOW MY PARKING LIGHTS STAY ON WITH THE HEADLIGHTS. I KNOW THIS IS A LITTLE WORDY, BUT I HOPE I ANSWERED YOUR QUESTION, INCLUDING SOME YOU DIDN'T ASK. MIKE
pickup6772 is offline   Reply With Quote
Old 06-24-2003, 09:38 PM   #5
67sss
67sss's Avatar
parking lights
67's parking lights are not suppose to stay on when you turn your headlights on, one of those unique things for a 67
67sss is offline   Reply With Quote
Old 06-24-2003, 09:38 PM   #6
jhow66
jhow66's Avatar
They are suppose to go out when headlights are on (tail lights stay on). Cannot remember what year they started to stay on. As to blinkers, you may have a bulb out on one end or a weak flasher.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-25-2003, 12:33 AM   #7
67_SS396
However, it's quite easy to wire the lights to come on with the headlights. I prefer that look, so that's how I did mine. All you have to do is find the wire that runs the park lights at the switch. Find where it's hot when the switch is turned to park lights and headlights and move the wire there. I believe it is the purple wire.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
