05-14-2013, 10:23 PM | #1 |
Air conditioning
I'm on a super low budget so does anybody know a cheap fix for some air con. other than rolling the windows down. (p.s. I'm not a panzee)
05-14-2013, 10:37 PM | #2 |
Re: Air conditioning
Are you asking how to fix existing air conditioning, or how to add air conditioning?
If you're asking how to fix your AC, we kind of need to know what's wrong with it. If you're looking to add AC, there really aren't any cheap fixes. |
05-14-2013, 10:42 PM | #3 |
I'm looking to add air!
05-14-2013, 10:47 PM | #4 |
Moderator
AC and cheap don't go together...plan on $1000 whether you buy a Vintage Air kit, or piece together a factory unit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-14-2013, 10:47 PM | #5 |
Vintage air is the only way to go. Save your money and do it right the first time. You get what you pay for.
05-14-2013, 10:49 PM | #6 |
Yeah what ledzepp said. Fixing or adding AC is usually never cheap.
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
05-14-2013, 11:02 PM | #7 |
Alright thanks guys.
05-15-2013, 07:45 AM | #8 |
Old member
I don't know how cheap it is but there is a older way to add AC.
Here is a thread on them. http://67-72chevytrucks.com/vboard/s...d.php?t=330490
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 05-15-2013 at 11:38 AM. |
05-15-2013, 10:59 AM | #9 |
Save your lunch money and buy vintage air. Did it myself and love it.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130 Club longbed ...cause girls like'em long!!!!! |
05-15-2013, 11:08 AM | #10 |
You should call Jethro Air. I think they're located in Beverly Hills.
05-15-2013, 12:43 PM | #11 | ||
You can do this for WAY under $1000. I converted a non-AC truck for way less than that. It would be even cheaper if your truck came with AC. I used all 67-72 vintage stuff. Others on here have used newer style GM stuff. Click here and scroll down to post #8 for a price list: http://67-72chevytrucks.com/vboard/s...d.php?t=478564 With this inflation period we are experiencing I'm sure each piece costs a bit more but even then you are WAY under $1000.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
05-15-2013, 01:33 PM | #12 |
Old member
If everyone on this board didn't do something differant than what the other person say's is wrong are not possible this board wouldn't be so awsume!
The guy asked if it was possible and most of you told him no! Well I think it is also as I stated before and as mrein3 stated. Yes it can be done for cheap if you can find a junk AC truck. U need the right truck to get all the parts off of it as I did mine back years ago. I ran all factory AC stuff for a long while until I upgraded it to 134-A stuff. YES it can be done so don't let the ones who say no change your mind.
05-15-2013, 02:50 PM | #13 |
Moderator
Anything is possible...
If you count the time you spend cobbling something together, buying the equipment to charge and evacuate the system, buying a junkyard compressor and hoping it works...IMO you are better off spending $1000 on a VA kit and knowing for a fact it will work, than gambling and hoping it works. I define "working AC" as air that is 40 degrees or below...someone who lives in a colder climate might define it differently. I never said anyone was wrong or it couldn't be done. That IS what makes this forum great, lots of different perspectives, opinions, and experiences. My experience is that junkyard AC parts are just that...junk. Others may have had better luck but I will never go that route again. Posted via Mobile Device
05-15-2013, 03:34 PM | #14 | |
Old member
My factory AC is still running fine today and with the new compressor it runs 38 degree's all day long no matter what the outside is once it cools off.The fact is it can be done so I say to u Bueno 68C-10 go for it!
05-15-2013, 03:47 PM | #15 |
Moderator
So how many compressors did you go through before you finally got it to work consistently?
05-15-2013, 04:28 PM | #16 |
Old member
The junk compressor last 1 year. The reason I had to change them is the old A-6 compressor I found out don't like cycling on/off as the new system do. It would burn the clutches up.
If I had put it all back stock as it was suppose to be it would have been fine I think. Who knows because I can't leave nothing alone. The other two compressor where rebuilt ones that I bought out of the store. 1 is for R-12 the other was the first one I bought for 134-A. Now I have the little sanderson and it's been working fine now for 4 years.
05-15-2013, 04:38 PM | #17 | |
05-15-2013, 04:40 PM | #18 |
le zepp "If you count the time you spend cobbling something together, buying the equipment to charge and evacuate the system, buying a junkyard compressor and hoping it works...IMO you are better off spending $1000 on a VA kit and knowing for a fact it will work, than gambling and hoping it works." It's funny cause it's true!
05-15-2013, 05:55 PM | #19 |
>> junkyard AC parts are just that...junk. <<
>>buying the equipment to charge and evacuate the system<< A Vintage Air or any other kit or any something cobbled together still requires the exact same. You don't buy a Vintage Air, throw it in the garage and wake up in the morning with a working system. You would be smart to flush even new components that came in a kit. If you have any kind of a clue about cobbling together junk yard parts, you just might have the ability to evaluate and select usable parts. Anything else comes under the category of 'when in doubt, throw more money at it and it should work". Sanden 508 removed from VW cabriolet Parallel flow condenser removed from Chrysler 300M AC/on full time fan from '94 Cadillac DeVille Secondary fan from '89 Cad DeVille controlled by 208* Honda temp switch Electronic Climate Control evaporator removed from '88 Lincoln Mark VII Couple relays removed from various GM vehicles Did use new R134, new ester oil and new hoses. GGGG Works like a champ. Set the temp desired and it mixes the hot and cold automatically, winter and summer. This is not for everyone. Each person has to make his own choices based on his abilities and the amount of work he is willing to undertake. That old stereo is gone. Put in one with bluetooth last summer. Cup holder is toyoto. Even junkyard import crap is worth something
'67 GMC 2500, 292, 4spd, AC |
05-15-2013, 07:40 PM | #20 | |
Old member
RichardJ, how many times during the build did you hear u can't do that are that is cobbled up!
05-15-2013, 08:00 PM | #21 | |
05-15-2013, 10:10 PM | #22 |
Old member
RichardJ,
Can you PM me some info on the dash controller and how it works. This would be a nice feature in my cab. I'm not scared to cut it. Thanks! Very cool.
05-19-2013, 12:19 PM | #23 |
I actually saw this on the interstate last year- hard to see but plywood back window with a house window ac unit installed in it with a gas generator strapped in the bed..
Dave aka "Wild" Current truck "Ida Mae" 71 K5 Blazer Former Trucks "Loretta" 71 Longbed (AZ) "Tanya" 69 Stepside (AZ) "Ferdinand" 71 Longhorn (SD) "Patches" 67 Panel (IA/ KY) "Rosita" 68 C30 (KY) Instagram @Wildforwheels @k5_klub @c10university Profile pic provided by Jeff Sundance |
05-19-2013, 12:47 PM | #24 |
