Mirror mount location. 65 chevy
Was at the swap meet and came across a pair of bran new repo doors in the boxes. $400 for the set! Needless to say I drained my wallet and took those suckers home. My doors were beyond repair . The new doors fit great and all the holes are there but they weren't drilled for mirrors. I have the original style round mirrors and arms but drilling holes in new doors is scaring me a little. Anyone know of any Templates to help me? Or Possibly measure and post pictures? Thanks
Posted via Mobile Device |
Re: Mirror mount location. 65 chevy
Can't you use the old doors for numbers? There is a support bracket inside the driver door if it has different mirror arms than stock. This will show you where the original mirror arms went. Mark the holes on your old door and make a template for the passenger side.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
reach inside the doors and see if the mounting plate is attached to the underside of where the mirrors are supposed to be.
if they are there, then use a punch to mark the placement of the holes and carefully drill them out.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Here`s a couple of pics for referance, the second pic shows the screws sticking thru the backside...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
![]() Join Date: Jun 2011
You also might want to use the black gasket for a template for the mounting hole locations
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Should be close!
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
I'm just glad to be here!
That drawing looks like for a 60-63 cab. For a 64-66 cab/doors, the 2" dimention should be from the body line just below the window. If you are doing both sides, then they should match real well.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
