Old 05-15-2013, 03:28 AM   #1
msaintg
msaintg's Avatar
door latch help needed
hi guys,
I need your help. I finally got my doors to close properly, but now I can't get them to latch properly. The stock door latches do not seem to 'cam' over and catch the striker plate. The tiny 'lock' tab/pin is the only thing that holds the door closed. If I use the outside handle to open the doors, the lock pin pulls up and the door opens, but the pin will not come back down and the door no longer 'latches'. Do I have the striker plates upside down or something? I can't figure out what the 'cam' mechanism does.
I know, I know, i should have just bit the bullet and got the easy latches, but I thought the stock latches would work for a while so I could put my money somewhere else.
thanks,
msaintg is offline   Reply With Quote
Old 05-15-2013, 09:20 AM   #2
mknittle
mknittle's Avatar
Re: door latch help needed
I hate those latches!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-15-2013, 01:27 PM   #3
oldcouple
oldcouple's Avatar
You may have the latch plate too far in, loosen it up and allow it to "float" on impact, then firmly, almost slam the door. Then open it and re tighten, repeat. When adjusted correctly the cam should pull the door the last quarter inch tight. Its a Chevy, slam it, it can take it.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 05-15-2013, 06:33 PM   #4
msaintg
msaintg's Avatar
thanks guys,
there is no adjustment in/out on these striker plates. I thought about e-longating the mounting holes, but then I realized the new repro latches were just crap. I sent them back today and have bit the bullet and have Easy Latches on the way. Oh well, I was over budget anyway.... and it is a safety thing anyway.... right.
Old 05-15-2013, 08:02 PM   #5
Bubba54
Yeah, I fought with the stock latches for while then went with the easy latch.
A couple of pics on my 54 GMC.
Name:  door latch 007.jpg
Name:  door latch 008.jpg
Bubba54 is offline   Reply With Quote
Old 05-15-2013, 10:59 PM   #6
mknittle
mknittle's Avatar
Attachment 1107827
Attachment 1107830
That's the way to go
Mark
My GMC build.
Old 05-15-2013, 11:02 PM   #7
mknittle
mknittle's Avatar
Originally Posted by msaintg View Post
thanks guys,
What's a budget? These trucks don't know what that is
Mark
My GMC build.
