![]() Join Date: May 2012
Frame/suspension questions
Hey guys,
i have my 71' c10 and a 69' CST donor with a Great Frame. i want to swap frames but i want to keep the 71 disc can i just swap over the front ends an rear ends ? Will it be hard? or can i just put the disc brakes an spindles on the 69 a arms ? |
Re: Frame/suspension questions
just remove the crossmember and discs as one unit and bolt to the 69frame
do i take the whole set up a-arms an all ?
#4 | ||
"I ain't nobody, dork."
Yup...
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
ok, I know we had this talk about just driving it like it is ...but I Dont have anyother time to do this so im doing it now while i have the time.
#6 | ||
Go for it...
Gary
Junior Member
When we built my '67 on a '69 frame we took everything off a '71 so it would have disc brakes in front and 5 lug bolt pattern.
No matter which way you do it make sure you use the master cylinder off the disc brake system. We did have to elongate a few bolt holes when we put the '71 cradle on the '69 frame if I remember right. When we moved the '71 rearend over to the '69 frame we took everything from the '71 including the track bar and trailing arms. It is a pretty straight forward swap though.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
