69 Longhorn Craigslist VA
72 Super LWB |
Re: 69 Longhorn Craigslist VA
I will be looking at this truck this Friday afternoon if anyone would like detailed info or pictures....
72 Super LWB |
Seller claims its a CST/10 with a rare Longhorn bed! So something is wrong. Looks like a regular LWB 1/2 ton to me.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
![]() Join Date: Dec 2012
Tim I'm sure you can answer this but were there any STOCK C10 or 4x4 Longhorns? I have always been told there were none of either.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#6 | |
4x4 Longhorns were not an option as there were no factory K30 chassies to base it on. By nature the Longhorn was a spare parts solution for a camper hauler that was easy, quick and cheap to get to market. There are no known "factory" K30 Longhorns but there may very well be a couple of period upfitted trucks as Napco and Marmon&Herrington built kits for the C30s. Been looking for one for years. The are pictures on my profile page and at www.rusticshadessiberians.com/trucks
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 05-16-2013 at 05:20 AM. Reason: typo |
#7 | ||
"I ain't nobody, dork."
Tim... your knowledge and amount of literature you have for these trucks never ceases to amaze me. Too kool for skool my friend.
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#8 | ||
While a factory C/10 on a Longhorn chassis is very unlikely as even a special fleet order anything is possible. So here is a picture of a true Longhorn bed showing the displaced front stake holes and extension. Also note the signature seams. In any case pictures would be great including the glove box option sticker and the vin plate. In fact if this is all new to you please review (or even print) the VIN and Model decoder pages linked in my signature. Who know maybe you will find a unicorn CE11034. :-) Welcome to the board.
#9 | |
Actually much of what I use can be downloaded and I have posted links before.
![]() Join Date: Apr 2011
Wow. That truck looks nice. Hard to tell from the pics but looks like its not a rust bucket.
Let us know if you dont buy it! Posted via Mobile Device |
One of the First
![]() Join Date: Jan 2000
Luv that dual mirror set-up... If was closer and had more time, room in my barn and...
I would be on it!
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#13 |
![]() Join Date: Oct 2011
i squinted as hard as i could and i can't see a "longhorn" seam.
he probably measured the bumper too or thinks its a longer bed because he can put a sheet of plywood in and still close the gate.
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
#14 |
First, Thanks for the welcome....
Looked at this truck this afternoon and have uploaded a few pictures. The pid is there but has been painted over, vin intact. Would make a great parts truck... Could this be a "homemade" Longhorn??????
72 Super LWB |
#15 |
Wow, Id be all over that if it was closer.
#16 |
A few more....
72 Super LWB Last edited by Bill Beasley; 05-17-2013 at 09:30 PM. |
#17 |
May go back and attempt to remove some paint from the pid...
#18 |
Cab swap it the first thing that comes to mind. Without seeing the frame and some section height measurements can't really tell you more. The bed is wrong for any C10 and 8-lug is wrong for any C10 period. Since I can't see anyone stretching a C10 frame then putting an 8-lug axle under it I'm going with "Frankentruck" C10 cab and VIN on a Longhorn, C30 Stepside or C30 Chassis Cab chassis. Beside the whole VIN transfer issue there is the fact this truck is close to its max titled GVW as it sits, empty! At best this is really just a parts truck.
Underside pictures are a must see. Measure frame section height. C10 6.04" height 2.53" flange width 0.156" thick Longhorn C30 6.11" height 2.46" flange width 0.194" thick Frame stamped partial VIN is in two locations.
#19 |
It's obviously not a C/10. The front end is 8-lug,too. It has had paint and body work. My guess is it's a Longhorn and when they repaired/fixed-up the body they replaced the crappy original bed with a modified 8'er. The cab may have been swapped,too,but it looks like that VIN-plate is glued on. They probably ground the back of the rivets off. Possibly needed a title
#20 | |
To the op - decent price for what appears to be a decent truck from the pic. Oops maybe parts ![]() Posted via Mobile Device
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" Last edited by Spartan; 05-18-2013 at 01:24 AM. Reason: Reread posts |
#21 |
Being a post-factory conversion there would not be a SPID RPO for conversions such as NAPCO or Marmon & Herrington offered. If it was done at a converter vs using a "field kit" there might be a ship through designation on the build sheet. Fender badges and modifed floor/frames for the conversion are typical but undatable. Did you look at any of my site's posted pictures Spartan?
#22 | |
Thank you Tim. I'll PM you if I have questions. I think a 1T Longhorn M&H with clearance... If one exists or not would be quite something. Posted via Mobile Device
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
#23 |
That SPID is easily red.
#24 |
what is the story on the 69 chevy ? what shape is it in?
