Old 05-15-2013, 04:05 PM   #1
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Anyone Running an "X" pipe on there exhaust?
How does your X pipe effect your sound of exhaust? Louder? Rumble? More power? Never done one but i'm gonna redo my exhaust soon. Also what mufflers are you running? Thanks
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 05-15-2013, 04:23 PM   #2
SS Tim
SS Tim's Avatar
Re: Anyone Running an "X" pipe on there exhaust?
In the past I have only run a crossover tube. Really no major downside as it helps. The exhaust is a little quieter due to the peaks being clipped from the exhaust notes of both seperate pipes.
Depending on the trans there can be some challanges with access and heat radiation control.
Convention says to place them where the paint stops burning off the exhaust pipes that you apply just for that reason with some hard running.
No matter what use flanges to attach and I would recommend a flex section as well for longivety and sanity.
SS Tim is offline   Reply With Quote
Old 05-15-2013, 04:57 PM   #3
BADPURPLE70CHEVY
406 Powered
Thanks sstim. Anyone else?
70 GMC
68 c10
2002 silverado
72 4x4
Old 05-15-2013, 05:42 PM   #4
msgdsrf
I have an X after 4-1 headers into Dynomax single chambers. No driving drone but still sounds V8 and agressive especially at low RPM's, open it up and it sounds race'y yet smoother than otherwise. I've never dyno'd this motor so no tellin about power. What to run.. duals or balanced and which type seem to depend on what else is in your exhaust system
msgdsrf is offline   Reply With Quote
Old 05-15-2013, 07:23 PM   #5
Robznob11
Robznob11's Avatar
https://www.youtube.com/watch?v=kVk9...e_gdata_player. Stock 6.com0 lq4 with tune and long tubes. 3" duals with x under crossmember into summit turbos with dumps. Yes 3" is over kill till i get the cam in lol! And its much louder when its off the jackstands and on the ground!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-15-2013, 07:31 PM   #6
Ryan Hubbard
I am running a blown 350 with Hooker Super Comps into a 3" X crossover and Walker Dynomax Mufflers. It gives a nice smooth sound, no drones and really nice sound when you open it up.
Ryan Hubbard is offline   Reply With Quote
Old 05-16-2013, 01:00 AM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=450871
here's a before and after using the same type of mufflers, one clip with no X, the other with.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
