Old 05-15-2013, 04:42 PM   #1
84 400
Sb 400 club
84 400's Avatar
Wheeling with a truck cap?
I know Larry ran a cap for a while and some others have aswell. I just picked up a cap for my 77 stepside. It is fiberglass and I am thinking the twisting of the bed is gonna destroy it. Can thos with experance coment on how the caps held up. Would leaving the mounting hardware loose help?
Thanks for the suggestions / input
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 05-15-2013, 04:49 PM   #2
modernbeat
modernbeat's Avatar
Re: Wheeling with a truck cap?
I wheeled with a fiberglass cap on my 2003 longbed 3/4 ton. Although it would twist a very small amount, the only real misalignment I noticed was in the hatch while twisted up. I would keep the hardware tight or the cap can walk on the bed and eventually contact the cab.
modernbeat is offline   Reply With Quote
Old 05-16-2013, 12:56 AM   #3
dieseldawg142
dieseldawg142's Avatar
x2 on the hardware, keep it tight. i have a canopy for my k30 crew & a hammerhead on my k1500 stepper,the only thing i've had 4byin is like modernbeat says, hatch out of whack. i also put a 6" piece of 1/2" oak under the clamps to help hold & on my hammerhead the rails are fiberglass, without it the clamps will chew up the fiberglass
dieseldawg142 is offline   Reply With Quote
Old 05-16-2013, 12:36 PM   #4
84 400
Sb 400 club
84 400's Avatar
My cap is bolted to the bed rail using fender washers to help spread the load. But being a wood floor stepside it sure does twist a good bit. I have a run on saturday and I think I will give it a shot with the cap on.
1985 C10 LWB Sold
Old 05-17-2013, 01:21 PM   #5
dieseldawg142
if your canopy is bolted on, not clamps, dont see why you could'nt leave the hardware a little loose. maybe put 2 or 3 layers of sticky foam canopy tape under your rails to absorb some movement. my hammerhead is 100% fiberglass, except for the windows, over 20 yrs old, goes off-road all the time, gets a little flexed, no cracks or stress marks anywhere. 2 screw caps have popped off the rear hatch from flexing though
Old 05-19-2013, 05:15 PM   #6
Zoomad75
K5Camper
Zoomad75's Avatar
Having spent many a mile off road choking on Larry's dust I can say his cap stayed put. If you use the clamps to connect the cap to the bed the cap will ride right along. Every truck differs a little, but where most of the flex is in the frames on these trucks. With the cap secure it didn't move. I have seen up to 4 inches of mis-alignment from the bed to the cab and the cap was fine on Larry's. I think a good quality, heavy fiberglass cap will help stabilize the box more than anything.
Larry would probably answer in a couple of days. It's going to take that long for him to float back down to earth from getting his beast shot for a magazine spread by Rick Pewe himself today.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
