help w/plumbing hydraulic clutch stainless steel AN line & fittings
Im trying to make a stainless steel AN line for my hydraulic clutch conversion. Novak says the fitting is a 3/8-24 female double flare and the line will be around 3' total. they recommend a 1/4" DOT line, so will a -06 line be to big or should I go with a -04? Also....as for the hard fittings....comingh out of the cluth slave and the master cylinder, will a regular flare fitting work or will I need to try and locate double flare fittings? This is my 1st hydraulic clutch conversion and I don't mess with lines other than brake/fuel/oil pressure very often, so I'm out of my scope of practice. Any help would be appreciated. Novak sells a line for $90, but I can get the anodized aluminum fittings and real braided line for around $35 plus shipping through Jegs or Summit. both have 3/8" npt/-06 (2.99) and 3/8"npt/-04 (2.99) flare fittings and pre made -06 & -04 lines made for $28.99
So basically trying to plumb from slave cylinder to clutch master. -06 and -04 would seem too large....-03 is available through some place and possibly -02
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 05-15-2013 at 08:49 PM. |
Re: help w/plumbing hydraulic clutch stainless steel AN line & fittings
I can get 3/8-24 to -03 fittings and 3' -03 clutch line for $35. Fittings from russell and hose from online catalog.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: Jul 2009
Ahh...i was looking for that. I get their catalog, and knew that I had seen a chart somewhere before. Thank you. That'll help a bunch. So it's looking like -03 line is the way to go then. I'll work on the proper master cylinder and slave cylinder fittings tomorrow. Will also post a pic of the slave cylinder as Novak has changed it since the last one I saw on their website.
if your line is to large (-06) it will increase pedal effort, the smaller (-04) is better suited for clutch and brake applications. -06=5/16, -04=1/4,-03=3/16 ,hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
After alot of research and reading on this, I think -04AN is the way to go. -03/-04 seems to be the popular choices for most street vehicles and -03 for most motorcycles.
What I ordered was 1/8" NPT -04AN for the Wilwood master cylinder, 36" -04AN stainless braided HP line and 3/8" -24 IFM /-04AN for the slave cylinder. This should be the correct flares and adapters and total cost through summit $35.89. I think that Novak cannot be beat on their price for the conversion kit, but saved $54 on making my own line. That'll cover some more parts down the road.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 05-16-2013 at 09:34 AM. |
Heres pics of the parts
Will get some pics this weekend. The Novak slave was actually 7/16, not 3/8, but no biggie. Summit took the 3/8 fitting back and sent the correct one. Went w/-4 An line.
