Old 05-15-2013, 09:33 PM   #1
Boss hawg
8 board bed or 9.....
I'm figuring parts for my bed and not really sure wether I should get parts for 8 or 9 board..... I guess they don't really matter as far as looks I will probably like both but the only thing I have to question is putting a tank under the bed. If you put the filler in the bed floor you would need a board running directly center for cosmetic looks right? Other wise the filler would be off center.... Any help or suggestions on this is greatly appreciated, thanks.
Boss hawg is offline   Reply With Quote
Old 05-15-2013, 10:49 PM   #2
Boss hawg
Re: 8 board bed or 9.....
Nevermind I just figured out that the 54 has a 9 board.... I'm still not sure why they sell an 8 and 9 board cross sill for the 54 bed if it had a 9 board bed.
Old 05-15-2013, 11:17 PM   #3
Boss hawg
Of anyone could so kindly as to point me in the right direction for a bolt kit to put it back together minus the wood... If it comes with the wood bolts so be it they'll get used eventually but I need a kit that bolts the sills and front panel back up. Only thing I have found is a whole body set
Old 05-15-2013, 11:49 PM   #4
Bierkan
Bierkan's Avatar
They changed to an 8-board bed from a 9-board bed in 1951.
James "Bierkan" Vierkant
1950 3100 on a 1972 C10 Chassis
Truck Blog
Motorcycle Blog
Bierkan is offline   Reply With Quote
