Old 05-15-2013, 11:16 PM   #1
kcfirstbuild
Adjusting door with fender on
I really don't want to take my fender off cause it was a b to even put on. But now I have to move the door forward. My question is does the door hinge wrench work on our trucks. I know worse come to worse ill take the fender off.
kcfirstbuild is offline   Reply With Quote
Old 05-16-2013, 05:43 AM   #2
rustypu
Re: Adjusting door with fender on
I tryed using the hinge wrench but found my ratchet wrench worked better. you get a very short throw, but it can be done.
rustypu is offline   Reply With Quote
Old 05-16-2013, 06:51 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I think I did that once. I know I replaced a top hinge already with door and fender on.
If I recall, it does take a while as you can only turn some bolts a little at a time. Fun, fun, fun.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-16-2013, 08:38 AM   #4
KellerMAC
KellerMAC's Avatar
Bobs,
Are you saying that you can take off the top hinge without taking off the door? I need to replace the hinge pin on the top one and have been dreading taking off the door.
KellerMac
Texas - Don't Let The Size Scare You!
KellerMAC is offline   Reply With Quote
Old 05-16-2013, 08:53 AM   #5
kcfirstbuild
No i just need to loosen the bolts that are under the fender so I can move the door towards the core support. I put my latch on last night and when it latches it so tight I cant even open the door. so I have to move it to get a bigger gap.
Why didnt anyone tell me to never take my doors off !!! HUH
Old 05-16-2013, 10:42 AM   #6
KellerMAC
KellerMAC's Avatar
Here's the real question - can I replace the top hinge pin without removing the hinge?
Old 05-16-2013, 04:15 PM   #7
pennhunter
pennhunter's Avatar
You probably can if you remove the door and leave the hinge attached to the cab. I'm not sure about clearance issues getting the new pin in though.
pennhunter is offline   Reply With Quote
Old 05-16-2013, 05:09 PM   #8
tr69c10
I changed my door pins with the doors on take the wiper cowl off
tr69c10 is offline   Reply With Quote
Old 05-16-2013, 07:56 PM   #9
kcfirstbuild
what happened to my question ?
Old 05-16-2013, 08:55 PM   #10
tr69c10
How much forward is it if it just a little you can shim the door between the hinge with body shims
Old 05-16-2013, 09:33 PM   #11
GuyO
GuyO's Avatar
There are usually shims behind the latch mounted to the door post. Take those first if any. If not then fender off. Because you will need to adjust your gaps. Maybe even the cowl gap will need to be adjusted also after moving the door forward. Just did this on a 72 Blazer.
GuyO is offline   Reply With Quote
Old 05-16-2013, 11:28 PM   #12
kcfirstbuild
Im going to try a Half moon wrench to loosen the bolts under the fender. Lets hope it works.
Old 05-17-2013, 06:35 AM   #13
bobs409
bobs409's Avatar
Originally Posted by KellerMAC View Post
Bobs,
KellerMac
Yep, I did it. Just support the back of the opened door with a jack or blocks of wood.
Bob
