05-15-2013, 11:23 PM | #1 |
avs paralle4 link
http://www.avsontheweb.com/product.p...cat=335&page=1
does anyone know if this will work on a 73-87 with a truck 12bolt? Im just curious if the part that you weld onto the axel housing fits right, it looks pretty universal. Also, is a parallel 4 link good? or should i go with a wishbone 4 link, or a triangulated 4 link?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
05-16-2013, 02:40 AM | #2 |
Re: avs paralle4 link
It does look universal to me,But it depends a lot on what your trying to do with the truck.Are you going to bag it or run coilovers and are you going to lay frame or just lowered?
05-16-2013, 11:27 AM | #3 |
I plan on bagging it. Idk about laying frame but I'd definitely like to be as low as possible in the back.
Posted via Mobile Device With out having to z the frame or anything I want to bee as low as possible on a 28 inch tall tire
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. Last edited by Mikec10; 05-16-2013 at 11:48 AM. |
05-16-2013, 04:52 PM | #4 |
AIRBAGPARTS.COM
Our parallel 4-link is universal. It is designed to fit a 3" rear axle tube. But can be easily modified to work with a 3.5" or any other size tube you are running. That link also is our most popular with leaf spring GM trucks, where the gas tank will not affect the travel of the links.
05-16-2013, 07:26 PM | #5 |
Awesome all I needed to know is if it fits a 3" axle tube. Thank you very much
05-16-2013, 08:00 PM | #6 |
Not to highjack too much but how thick are the bars and tabs? Are they ready to ship?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
05-17-2013, 02:43 AM | #7 |
The rear is easy to lay frame,But the front won't lay frame with out a zing or aftermarket front suspension like a dropmember or ifs from scotts.
05-17-2013, 05:45 PM | #8 |
AIRBAGPARTS.COM
05-17-2013, 06:45 PM | #9 |
Looks like I will be going with that kit! (sadly not for a few months though)
05-19-2013, 09:12 PM | #10 |
I've been looking at the 4 link kit, and like the know the length of the links and from the axle tube mount to frame mount. Thanks
05-20-2013, 07:53 AM | #11 |
Give Jason a call his number is in his sig.
