Old 05-16-2013, 01:16 AM   #1
albaniadiadem
what can i expect
I have a 350 block bored over 40 with flattop pistons, vortec heads, lunati cam 468 lift, performer intake, Q-jet carb, 1 5/8 hedman headers, 2 1/2 dual exhaust with h pipe. My question is what kind of hp and torque can i expect with this setup?
albaniadiadem is offline   Reply With Quote
Old 05-17-2013, 09:16 AM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: what can i expect
No replys.. ill bite and guess around 350hp
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 05-17-2013, 10:27 AM   #3
Longhorn 70
Longhorn 70's Avatar
There are so many variables to give an accurate guess. Where are you measuring the HP? Rear Wheels or flywheel? Do you have accessories on and included?
I would guess if it is set up right and tuned you could get around 330 HP at the flywheel and depending on cam timing maybe 400 LB/FT of tourque.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 05-17-2013, 12:27 PM   #4
Fldawg
Fldawg's Avatar
do the flat top pistons have 2 or 4 valve reliefs and what is your compression, maybe 9 to1 if so i would agree with longhorn between 300 to 325 hp
Fldawg is offline   Reply With Quote
Old 05-17-2013, 01:28 PM   #5
albaniadiadem
The piston are 4 valve reliefs. Yeah i meant hp at the flywheel.
Thanks for the responds.
Old 05-17-2013, 03:10 PM   #6
Longhorn 70
go to the compcams camquest tool. If there is a cam that is CLOSE you may be able to play with the numbers there to get close.
Take it to a dyno. Add 15% for manual trans, 17% for auto. Add 50HP or so for the alt and PS pump. You can get a better idea of what it will do at the flywheel.
With the setup you have, it still should scoot right along and surprise you.
