05-16-2013, 02:31 AM | #1 |
bolt on bags
Any of you guys running bolt in air bags, and what are the pros and cons on the set up... And if there's any pictures that show height that would be great. Thanks fellas.
(Any of you guys know how to upload pictures via phone. Android so, no iPhones) Posted via Mobile Device |
05-16-2013, 02:54 AM | #2 |
Re: bolt on bags
A quick look to the top of the forum you will find this- http://67-72chevytrucks.com/vboard/s...d.php?t=507577
The pics have to be hosted in order for them to be posted. You will need to find a hosting service that can be accessed from your phone. |
05-16-2013, 08:36 AM | #3 | |
Re: bolt on bags
How low do you want to go ? here is a link to my build showing the transition from stock to lowered. My next step is to do a mild notch and then change the front springs and front tires. Adding bags to the rear is the first step in being able to adjust the stance of your truck. stock with 15" 235/70 tires: http://kieth.smugmug.com/Trucks/66-G...5257&k=RQTptm2 first iteration of rear bags: http://kieth.smugmug.com/Trucks/66-G...4BKf&lb=1&s=X2 later we removed the bottom cage and bolted the bag directly to the trailing arm: then installed a lowering block: http://kieth.smugmug.com/Trucks/66-G...3351&k=9b7PbpP before picture without front drop spindles: http://kieth.smugmug.com/Trucks/66-G...1202&k=w9XC84h pictures after the drop spindles: http://kieth.smugmug.com/Trucks/66-G...6507&k=dJxggwv If you want to go farther than this it gets expensive and can involve modifications to the rear frame all the way to replacing the rear suspension altogether. At the front of the truck you can pancake the front crossmember, add air bags to front, or install a complete Porterbilt front suspension. Hope this helps a little. Kieth |
05-16-2013, 11:56 AM | #4 |
Re: bolt on bags
Very helpful thanks, right now it's sitting lower than what you yours at, mine is on cut spring coils. But it's too stiff bouncing.. I'll find the thread so you can see how low it is. and how low I want it with out notches on the frame... Thanks for showing your set up, how does it ride
05-16-2013, 12:11 PM | #5 |
Re: bolt on bags
http://67-72chevytrucks.com/vboard/s...=507575&page=9
Miayota green truck... Posted via Mobile Device |
05-17-2013, 11:41 AM | #6 | |
Re: bolt on bags
here is a project we call Corina Patina but she has not had a lot of attention lately. http://kieth.smugmug.com/Trucks/65-C...KZgGh&lb=1&s=A |
05-17-2013, 01:01 PM | #7 |
Re: bolt on bags
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
05-17-2013, 01:09 PM | #8 |
Re: bolt on bags
Here some from the Tuckers show and an older one with side pipes.
05-17-2013, 05:08 PM | #9 |
Who Me?
Re: bolt on bags
Look at my build page and you will see my rear bag setup.. I don't have bags in the front yet.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
05-17-2013, 07:59 PM | #10 |
Re: bolt on bags
I just went straight to the frame with no cups for my rear bags. Used Slam 7's with some precut little plates top and bottom just because I had them and thought they might add some support to the bag endplates. I just drilled 3 holes in the frame, two 3/8" for the bolts and one 1" in the center for the air fitting. The bottom mount is a 3/8" grade 8 bolt through the existing hole in the trailing arm. The drilling is tough, get a couple of good bits, the frame is hard and thick!!
05-17-2013, 09:06 PM | #11 |
Re: bolt on bags
I know you said you dont want to c-notch but wanted to show anyone reading this thread how low you can go with just basic bolt in bag plates,bags , and bolt in c-notch and lowering blocks....heres a video of mine with a basic bolt in bag plates up front and basic bolt in c-notch in the rear with the bags just bolted to the frame and trailing arms with the pre-cut plates,and no cups in the stock spring location and 2" lowering blocks...i did raise the whole bed wood floor and wheel wells up a 1 1/2" to allow the rear end to sit all the way into the c-notch without the rear-end pumpkin hitting the bottom of the bed wood, also flipped and repositioned the center driveline carrier bearing mount to correct driveline angle at ride height, and relocated rear shocks:
Click picture to view video( I have manual paddle valves so my air bags are really slow): This stance is about how low you can go with stock front spindles and bolt in bag plates, and the bed wood raised with a basic c-notch and bolt in bags in the rear with 2" lowering blocks.....if you want to go lower you will have to start doing extreme modifacations to the rear frame and front lower control arms or drop spindles,pancaked crossmember, or porter built stuff.. LOL and after doing all the work to get the truck lowered on bags, I drive around most of the time like this....SKY HIGH!
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 05-17-2013 at 09:34 PM. |
