Old 05-16-2013, 06:24 AM   #1
Sloan66
Horn won't work
I put a 68 wheel on my 71, I have all the guts for the 68, replaced the relay when I press the button you can hear the relay clicking but no horn. Any ideas? Just got the truck running working all the bugs out as it will be a daily driver.
Sloan66 is offline   Reply With Quote
Old 05-16-2013, 06:30 AM   #2
50bomb
50bomb's Avatar
Re: Horn won't work
Was the horn working before you put a new horn cap on? On my 67 project we finally got around to putting on a horn cap so we tested it seems the same as yours where I can hear the clicking. We light tested the horn and no good. Maybe replace the horn itself.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 05-16-2013, 06:37 AM   #3
Sloan66
Re: Horn won't work
Not sure as the truck was not running when I bought it and I never tested it with the original wheel. How can I test the actual horn to see if it is bad?
Old 05-16-2013, 06:59 AM   #4
50bomb
50bomb's Avatar
Re: Horn won't work
There is a light tester you can buy at an auto parts store to see if its got juice or ground to it.
Old 05-17-2013, 09:31 AM   #5
Sloan66
Re: Horn won't work
Checked voltage, get 12 v to horn when button is pressed, apparently I must have a bad horn.
Old 05-17-2013, 09:42 AM   #6
Mister-B
Re: Horn won't work
Yeah, sounds like a bad horn or maybe bad wiring to the horn. One trick when installing a new steering wheel and horn assembly, is to unplug the connector from the back of the horn. You can hear things click to let you know the horn button works, without annoying everyone with constant honking. Then, you just plug it back in.
Mister-B is offline   Reply With Quote
Old 05-17-2013, 04:14 PM   #7
68c10airstream
68c10airstream's Avatar
Re: Horn won't work
Hi, possible bad ground, rusty dirty mounting bolt. With the horn in you hands, a volt/ohm meter should show maybe 10 ohms, between the blade terminal and mounting eyelet, don't exactly know the value but a completed circuit none the less. I have brought more than one horn back to like with a rap from a ballpein hammer, but is usually short lived. Good luck, Brian F
68c10airstream is offline   Reply With Quote
