Old 05-16-2013, 07:22 AM   #1
Thealien
Thealien's Avatar
Transmission cooler
I have a transmission cooler for sale in the misc parts section. It is a derale aluminum external cooler unused and almost 1/2 the price. Just thought some of you guys swapping might not think to look there.
Transmission cooler
Old 05-16-2013, 12:15 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Transmission cooler
how well do those cool?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-16-2013, 09:33 PM   #3
Thealien
Thealien's Avatar
Not sure, never used it. I bought it off 68shortstep when he worked on my harness. Its what he used?
Old 05-17-2013, 11:29 PM   #4
68GMCCustom
I'll take it.
Kurt -
Old 05-18-2013, 01:11 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've heard they work well in conjunction with the in-rad cooling loop, or if mounted in a high-flow area.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-18-2013, 06:48 AM   #6
Thealien
Thealien's Avatar
Originally Posted by 68GMCCustom View Post
I'll take it.
PM replied to.
Mark
Old 05-18-2013, 10:00 AM   #7
wgeyer88
Any idea if they can be used as an alternative to the radiator? I've thought about using one of these but there's not a lot of info on them out there
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 05-18-2013, 01:42 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If you intend on running a stand alone cooler (I chose to, my radiator didn't have a provision for the trans), I would go with a "radiator style" FAN COOLED unit. Most unit don't get enough airflow to completely cool the trans themselves, especially being mounted behind a radiator. Keep in mind that standing still, a non-fan cooler gets no air movement and will diminish any cooling ability it afforded. Sitting in a staging lane with your trans cooking isn't fun.
Old 05-18-2013, 01:49 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Old 05-18-2013, 02:18 PM   #10
68GMCCustom
I've had a couple of folks say these new heat sink style work well enough to be a stand alone. Not sure I believe it...so I thought I'd try adding one and/or use it for something else if needed.
Kurt -
Old 07-26-2013, 08:48 AM   #11
LDO
LDO's Avatar
Any pictures of it mounted? I'm having a tough time trying to figure out where to mount mine.
LDO is offline   Reply With Quote
Old 07-26-2013, 11:27 PM   #12
mooseknuckles
mooseknuckles's Avatar
I have the same one mounted under the bed....
mooseknuckles is offline   Reply With Quote
Old 07-26-2013, 11:46 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its a weird angle, and I can't get a picture with the bumer on. Its in between the front frame horns facing down.
My build has a couple more pics of the install.
Old 07-29-2013, 01:35 PM   #14
Hart_Rod
Hart_Rod's Avatar
What's the part number and price? Have you put a temp gauge on it to see how it cools?
Hart_Rod is offline   Reply With Quote
Old 07-29-2013, 03:02 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Oh your just assuming I have a massive archival of every cent I've spent on the truck?
I totally do;
from jegs
259-13270 electra cool trans cooler 145.99 (1)
555-100001 #6 Straight hose end 4.99 (2) 9.98
555-100021 # 6 90* hose end 11.99 (2) 23.98
555-100911 #6 Hose 6ft 26.99 (2) 53.98
Plus the specialized 4l80e style AN fittings, but I had to order those elsewhere, I can dig up the source if need be.
I don't have a trans temp gauge but I can tell in stop and go traffic that it helps a good bit. Trans keeps cooler so I notice a little slower buildup of heat in the engine bay in traffic/staging etc.
Old 07-29-2013, 10:06 PM   #16
mooseknuckles
mine has a fan switch that comes on at 180* as for how hot it gets I'm not sure, but it never usually runs for a long time....
Old 08-01-2013, 01:36 PM   #17
Hart_Rod
Hart_Rod's Avatar
What's everyone's thoughts on this setup:
http://ls1tech.com/forums/pontiac-g8...r-upgrade.html
Old 08-01-2013, 03:22 PM   #18
jorgensensc
jorgensensc's Avatar
Looks like a good unit. I have to be honest, I just used the factory external tranny cooler that the donor escalade came with. I ran the lines to the stock escalade radiator, then to the cooler just like factory. Made some brackets to mount it in front of the AC condensor. The little I have driven the truck around it stays right around 160-175. About the same as my 2012 tahoe tranny does.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 08-02-2013, 12:35 AM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I don't put mine through the radiator, so anything less than fan cooled and I wouldn't be doing myself any favors.
