Old 05-16-2013, 10:43 AM   #1
tony58
Maybe a dumb question 71-72
I gave someone a pair of front brake hoses for a 71-72 disc brake truck 1/2ton. Aftermarket braided stainless steel. They say the female end on one side doesn't fit. They didn't make two different steel line nut sizes, did they?
The hoses have the appropriate banjo fitting on one end and a 3/8" female inverted flare on the other.
tony58 is offline   Reply With Quote
Old 05-16-2013, 11:00 AM   #2
vegadesign
vegadesign's Avatar
Re: Maybe a dumb question 71-72
i think the 1/2 ton and 3/4 ton used different sizes
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 05-16-2013, 11:07 AM   #3
tony58
Are you saying the 1/2 is different from the 3/4 or that the right and left have different size nuts?
Old 05-16-2013, 11:16 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
maybe you have two different wheel cylinders so they have different sized attachment points?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-16-2013, 11:31 AM   #5
tony58
Disc brakes. Flex hose goes from caliper to tab on frame where hardline ends are.
Someone is telling me the hose fits one side but not the other. I have never seen a vehicle with two different sized hardline nuts. Both sides should be 3/8" inverted flare as far as I know. I'm asking if these trucks came with different sizes, pass vs drivers side. I don't believe they would have but I don't know every thing about these trucks.
Old 05-16-2013, 11:38 AM   #6
VA72C10
VA72C10
VA72C10's Avatar
oops...forgot/didn't notice you said 71-72 w/ discs factory :facepalm:
Old 05-16-2013, 11:59 AM   #7
tony58
Possible one hose has bad threads or other defect, problem is I'm dealing with someone that can't explain the problem, just "it doesn't fit one side"
Old 05-16-2013, 03:06 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
My 72 1/2 ton uses two different part numbers for front beake hoses. I found out when i ordered hoses from the local parts house. Left side is one pn and right side is different. Same issue that op mentioned above.
WIDESIDE72 is offline   Reply With Quote
Old 05-16-2013, 03:12 PM   #9
WIDESIDE72
WIDESIDE72's Avatar
http://m.napaonline.com/parts/PartsL...Ntk%3dCategory
Old 05-16-2013, 04:12 PM   #10
tony58
Two part numbers because of the banjo head has opposite "tangs", I really doubt there's two different thread sizes at the female AN fitting but I'm not positive.
Old 05-16-2013, 06:09 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
There are two different sizes at the "hose-to steel line" connection.
(1/2-ton 2wd trucks)
I've heard you can use 71-72 4x4 hoses to get them the same for each side.
(as in converting from drum brakes to disc brakes)
Keith
Convert to disc brakes.
Old 05-17-2013, 06:36 PM   #12
mgchevyparts
mgchevyparts's Avatar
Yea Tony, the 71/72 hoses use 2 different size female ends. One side has 3/8-24 and the other is 7/16-24 an female fittings.
mgchevyparts is offline   Reply With Quote
Old 05-17-2013, 10:43 PM   #13
BigRed76
BigRed76's Avatar
I just replaced the front brake hoses on my '71 last weekend and the fittings that attach to the female end of the brake hoses are different from side to side. I believe the one on the pass. side was a little smaller.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 05-18-2013, 06:37 AM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
In reference to post number 2....
The difference between half and 3/4-1 ton hoses on 71-72 trucks is length. The heavy trucks used the exact same hoses as half tons, but with an added 3/4" of length. Those are the hoses I use on lowered trucks because the added bit of length makes the fit more comfortable on the dropped trucks. With drop spindles and drop springs on a half ton, the factory length hoses can get a bit taught for my tastes. The big truck hoses fix all of that.
