Old 05-16-2013, 11:30 AM   #1
dart_451
dart_451's Avatar
power steering seal replacement
hi, i have a 72 c10 and the seal around where the pitman arm is leaking badly.i tried all the differant fluids to help. but didnt. so. how hard is it to replace the seal.i have the pitman arm puller.anyone have any helpful hints on replaceing one? thanks
dart_451 is offline   Reply With Quote
Old 05-16-2013, 04:50 PM   #2
MARKDTN
Re: power steering seal replacement
I would almost say get another used or rebuilt box. I have not had much luck with replacing those seals.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-16-2013, 04:52 PM   #3
71K20chevy
71K20chevy's Avatar
Advance charges $140 for a new box, so I'd say just replace the whole thing.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 05-16-2013, 05:56 PM   #4
68gmsee
Active Member
68gmsee's Avatar
If you have the time and are fairly comfortable with mechanicking, it's not hard to replace the seals. I rebuilt my gear box about 1-1/2 years ago for the same reason and was surprised how easy it was to do. However you have to read and/or view videos and follow the procedures. Several videos on youtube and procedure on the net if you do a search.
Otherwise, as mentioned above, get a rebuilt one.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-17-2013, 05:59 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
No reason to replace the box for that leak.
Remove pitman arm. Remove snap ring. Place drain pan under steering box. Start engine and turn steering wheel lock to lock. It will blow the old seals out and they will land in the drain pan. Install new seals and snap ring. Reinstall pitman arm.
It's a 20 minute job am will cost you about 15 bucks including the fluid.
Worst case the seals won't blow out and you have to reach up in there and pull them with a pointy tool. That might add another 10 minutes to the job.
