Old 05-16-2013, 12:47 PM   #1
jorgensensc
jorgensensc's Avatar
VVT or Not?
So my ongoing saga continues. The harness I had made for the l92 swap did not come with the correct 5 pin plug for the cam sensor/ VVT solenoid. They did not run the extra 2 wires to the location for the VVT solenoid either.
I've been trying to read up on this and very confused. This will be a daily driver in a heavy 1972 suburban. I've heard VVT helps with low end torque/ high end horsepower, and about 10% fuel mileage gain. I know a lot of people run without VVT.
-- Should I make them fix the harness (or more than likely me since I already installed it and its a pain to uninstall) for VVT, or is it really not that big of a deal after all?
-- If I don't run VVT do I need to do anything special to the engine, or will the solenoid not being hooked up be all that needs to be done?
-- Will the tuner be able to delete VVT without throwing error codes all the time?
Thanks guys!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-16-2013, 02:31 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: VVT or Not?
My LY6 is/was a VVT motor. My custom harness was built to run w/o it. I changed to a Comp LSr non-VVT cam (also from 1 to 3 bolt), LS2 timing cover, LS2 cam gear, LS2 cam chain tensioner, etc to make the change. In the beginning I ran this motor carb'd so no ECM for the VVT and VVT is not really in its realm running high lift, longer duration cam's.
That said...........for your application I think I'd want the VVT capability for getting all the down low torque you can get. how to remedy...might be easier to add a small VVT harness to the existing. I think Mast is one of the leading aftermarket VVT related manufacturers.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
