Old 05-16-2013, 01:19 PM   #1
74 stepside
74 stepside's Avatar
Stepside Bed Question
Ive done bed wood in my 65 fleet, but Iam wanting to do it now on my 74 stepside. Question is..are the bottom side pieces spot welded to the sides? I removed all the wood except the 2 side pieces of wood because the "L" shaped side metal seems attached.
74 stepside is offline   Reply With Quote
Old 05-16-2013, 01:35 PM   #2
74 stepside
Re: Stepside Bed Question
These are the pieces Iam asking about.
Old 05-16-2013, 02:50 PM   #3
83GMCK2500
Looking at the page in the Illustration catalog, looks like it is part of the bedside. I have no experience with stepsides, other than admiring some nicely restored ones.
Looking closely it appears there is two spot welds, or two bolts bolting it to the side panel.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 05-16-2013, 03:13 PM   #4
1981Stepside
1981Stepside's Avatar
I just finished doing my bed and the angle strips are spot welded to the bed sides. To remove the boards on either side, you need to unholy the bedsides from the crossmembers and lift them off. If you also need to replace the steel, I believe there is a good how-to on mar-k's website. It involves drilling out the spot welds and welding the new angle strips in.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 05-16-2013, 10:46 PM   #5
Greenlee
Greenlee's Avatar
You can replace the wood without removing the spot welded angle strip. You have to destroy the original wood to get it out. Cut notches in the new wood where the bolts go through the angle strip and the wood will slip right in. You can't see the notches when it's installed. Here is a picture of mine that I recently did.
Greenlee is offline   Reply With Quote
Old 05-16-2013, 11:09 PM   #6
74 stepside
Thanks for the replies. I guess either leave them in or drill out all the spot welds to replace them like this..I prefer the look with ALL the stainless .
Old 04-29-2014, 03:46 PM   #7
larey
They are spot welded about every three inches, so that is a lot of drilling.
larey is offline   Reply With Quote
