![]() Join Date: Feb 2003
Daily Driver and Disc Brakes
I am in the process (slowwwww
Re: Daily Driver and Disc Brakes
I would go with some discs on the front and on the rear rebuild the drums, use quality components when you do the rebuild or order parts. That way you get good disc brakes on the front but still retain your parking brake in the rear with the drums.
If you think discs on the rear are a must, be prepared to spend 500+ to get a set up with an e-brake. Last edited by sprint_9; 05-16-2013 at 05:04 PM. |
Nobody i know of has ever complained that their brakes stop their vehicles too well. That being said, if you are hauling 1000lbs daily, then brake fade associated with drum brakes is inevitable. Disc/drum combos have worked and are effective, and could probably get you by safely. It would come down to how fast and safely you would like to stop, versus how much you would like to spend on brakes.
I daily drive my 1970 with disc's up front and drum rear and have had 800plus pounds in the back and stopped just fine with it.
Considering that you are running pretty much at design GVW now with the drum brakes, power front disc brakes will feel like a new truck. Go with a factory brake parts swap up front.
http://67-72chevytrucks.com/vboard/s...68&postcount=4 Add a front sway bar while you are there as well. Rebuild the rear drums with quality parts and premium shoes. But you do need to address the whole 5 or 6 lug issue so often wrestled with here. Hopefully your "cattle trailer" has good brakes and is not too heavy. With a max GCW of 10,500 lbs (4.11 gears) that would leave about 5500lb for trailer and cargo best case. If you are hauling loads like this often you might want to consider a heavier series truck.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Junior Member
I have run drums and disc on a daily driver and it is an easy choice to pick the disc brake set up.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Same as posted above.... power front discs and good rebuilt rear drums. You'll have all the braking power you need without the added cost & hassle of fitting rear discs and parking brakes. That said, I am a huge fan of 4-wheel discs -- but I also don't think it's worth the trouble to convert.
#8 | |
It already had a sway bar (15/16th) and I just replaced the bushings with Moog bushings. Also replaced the shocks and springs - changed the rear to cargo coils. If I have a heavy load I use my other truck, 78 K30 Flatbed dually. Posted via Mobile Device Posted via Mobile Device |
#9 | |
Maybe using the factory disc parts and aftermarket 6 lug rotors would be the easiest and cheapest solution. But the rotors would be a special part, thus a potential replacement issue. Sway bar I was thinking of was the 73 up 1 1/4" square body part. A 1000lbs in a C10 is a heavy load and you stated this is and will be a routine load. Also stated that you use or plan to use it to haul a cattle trailer this is also a heavy load anyway you look at it. Unless you have a healthy 350 or a big block in front of that three speed I can't see it being happy pulling that trailer.
It takes all of ten minutes a side to replace disc pads and you hardly get dirty doing it.
Front disc, rear drums. The difference will be noticable if you haul much at all.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
on the kids 67 we put manual 72 disc's up front and the 72 5 lugger in the rear(same setup i'm doing in mine) the later rear axle the drums/brakes are slightly wider than the 67's(if that makes a differnce).
after the swap it made a world of differnce in the pedal feel and stopping power even without power assist. driving my 67 around with the manual drums they worked pretty good but it did have alot of brake fade and you definitly had too hit that pedal alot earlier than in the kids truck so i can understand where your comeing from with hauling and useing the drums. swap over too the disc/drum setup you'll be much happier. i gotta say though my s10 has 4 w disc's with the fancy rotors and that thing can stop on a dime but its a whole differnt truck. we have never pulled anything or even really ever loaded the kids truck with much of anything so i couldnt help you in that department
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#13 | ||||
#14 |
#15 | |
Happy to be here
![]() Join Date: Mar 2000
Ok, heres the scoop as best I remember it. The following applies to 73-87 C/10, C20, C/30 trucks and up to 91 on Burbs C/10-C/20 and C30 old body style trucks. If its a C10 and has a sway bar it will be 1." and the C20's and C30's had a 1.1/8" bar. You will need the bar, the bushing clamps, and the bushing stands. The bushing stands will be rivited to the frame so you will need to cut them off. I recommend replacing the bushings with a good rubber or polygraphite bushing. Regarding the bushing stands, there are three ways to go. If your at stock height or slightly lowered you will need the stock stands. If your mildly lowered you can buy a shorter set from ECE that fit tighter to the frame. If your extremely low you can bolt the bushing clamps directly to the frame. Applications will vary so you need to decide based on bushings at the A arms binding due to mounting height.
#16 |
Yeah, that'd be sweet. I despise doing drum brake jobs. Slave cylinders get leaky, you (I, anyway,) always put some arm or plate on backwards and have to do it twice, and all that 2 tons of black soot gets everywhere. Fortunately, the rears wear so slow, you only have to do them maybe once for every two or three sets of front pads.
