05-16-2013, 04:36 PM | #1 |
You can't handle the truth!
What this really means:
End of the shift, end of the week. One of the guys that built your truck was having a bad week. His union rep. won't talk to him. Yesterday his wife filed for divorce. Overnight the cat napped and crapped in the laundry basket on his only clean work clothes and the car had a dead battery, again. Your truck is approaching his station. He simply does not care about the broadcast sheet, assembly drawing or the colors called for on his trim card. He has parts in his hand that need to be installed and another truck behind yours. Momentarily he considers; the truck will have one gold and one parchment arm rest. All it has to do is pass the next inspection, then it's someone else's problem. Wouldn't you like to know the actual day and shift your truck was built? A warranty claims auditor at GM did too...
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-16-2013, 05:11 PM | #2 |
Proprietor of Dale's Corner
Re: You can't handle the truth!
Yes, would be nice piece of info
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
05-16-2013, 07:16 PM | #3 |
Cluster King
Tim,
This is a good scenario and should always be considered when trying to figure out why some trucks/cars are not correct. Oddball things happen and human error is the most likely cause. My example was in 1993 when a gentlemen brought his 1989 Olds Ceirra into the shop I was working for a brake inspection. After removing all 4 wheels it was obvious right away that the left rear brakes were 7 inch and the right rear brakes were 8 inch. I asked about the history of the car, accidents or any warranty work and the owner stated that I was the first person to ever have the rear tires off and this was the first brake inspection. I told him he should contact the dealer in which he purchased the car and let them know of my findings. Was this car built on a Friday afternoon by someone who was working that station that had a similar situation with personal issues? We will never know. I am not sure what the outcome here was but these type of things happen more than we know. |
05-16-2013, 07:36 PM | #4 |
I used to receive cars for a Chevy dealer. We had a joke that you always wanted to buy a Wednesday car, because the Monday cars were built with a hangover and by Friday the workers were already getting started for the weekend.
We had a 76 Camaro come in just a few weeks after it was sold. There was a rattle the owner couldn't trace. I took the car out for a test drive, came back and pulled off the driver's door panel, and found an empty whiskey bottle. |
05-16-2013, 07:39 PM | #5 |
I love your scenario. Those kinds of things run through my head any time someone says "you get what you pay for". No matter how expensive something is, its still subject to have flaws and problems.
Posted via Mobile Device |
05-16-2013, 08:15 PM | #6 |
I worked for the local Chevy dealership through high school and for the summers during my first two years of college, 1996-2003. In the summer of 2002 or maybe 2003 we recieved a shipment of new vehicles and one of them was a maroon Trailblazer, some how some way that thing made it from the factory to small town ND with a full blown GMC Envoy tail gate. That is something I will never forget.
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
05-16-2013, 10:22 PM | #7 |
A friend of mine in the 80's was a service manager at a local Chevy dealer. He warned me of the same things.... Get a Wednesday car if you can. He told a story of several "Targetmaster 350" engines that were replacements for failed engines that came through the dealership with only 1 bolt in each main cap. You can guess how long they lasted.
I was in parts at a Datsun dealer, tells you how far back. An older gentleman brought his truck in for service with 136K on the clock needing a clutch replacement. Shortly before I left he brought it back with only 60K on the new clutch. We told him the replacement part may have been made on a Friday or he was riding the clutch too much. Thanks for the true chuckle, Tim.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
05-16-2013, 11:58 PM | #8 |
Without naming anything.
New parts manager, problematic, asks "Should I buy that car X?" Replied to the effect No not that car, don't buy that specifc option group and do not dealer install aftermarket modified wheels. Well long story short nighmare car. Somedays I still want to call and say "I told you not to buy that car"... it was built January 2nd! They never actually knew.
05-17-2013, 12:16 AM | #9 |
I built it
my folks got a brand new ford in the 90's with no shocks and 2 diffrent gear ratios in the 4wd. rear was 4.10, front was i think, 3.73. first time we pulled out of a field in 4wd the transfercase exploded haha
also heard a salesman say they had a truck come in once with a knock going around a corner. the repair shop pulled the door apart and found a washer tied to fishing line hanging there
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
05-17-2013, 12:37 AM | #10 |
You would not believe what the Fremont plant parking lot used to look like on Saturday mornings in the 70's - Empty sixpaks and bottles and cans and bottles and cans and sixpaks as far as the eye could see.
05-17-2013, 12:49 AM | #11 |
Moderator
This holds true in nearly every industry. You don't want surgery on a Monday or Friday either...for the same reasons.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-17-2013, 06:57 AM | #12 |
I was a tire guy in the early 90's and a fellow came in with a new Jeep. Said his right front tire the kept going low on air. I removed it and found a leak in the sidewall.?? So I go to replace it and let the air out and it smelled like starting fluid. BAD! So I filled it up and let it out several times and slowly took the tire off the rim and found enough shrapnel to equal a very large can of starting fluid or some other volatile liquid. We took the rest of the tires off just to be sure.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-17-2013, 07:10 AM | #13 |
I had scheduled oral surgery for a Saturday morning to have a wisdom tooth extracted. The last thing I remember before going under was the surgeon saying,"Let's hurry up and get this done. I have 18 holes waiting". I come to,he's off playing golf,and I'm told the tooth in front of it is fractured. It ended up being fractured so bad they had to pull the took. They were nice enough to do that for free.
05-17-2013, 07:34 AM | #14 |
These are 2012 models!
05-17-2013, 08:36 AM | #15 |
I am a Referee of life.
I worked with a guy who put left hand door panels on Thunderbirds in 77-78 IIRC.He claimed that if I ever bought one that there would be 3-4 screws in the door panel/handle assembly instead of the 5 it was designed with.The last screw was hard to get to,so nearly always left out.In fact he told me that the trainer showed him how to do the job and a day or so later,while he was still trying to get the speed required to do the job,the trainer came by and showed him the shortcut.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
05-17-2013, 10:08 AM | #16 |
I used to have a 2000 S-10 4WD, had it from brand new. For months, there was a clunk in the front end going over a bump with the wheels turned. Two dealerships went through 2 idler arms, 1 pitman arm, a PS pump and 3 PS hoses (one blew off before I left the lot) before I finally put it up on a lift myself and found that not a single boot in the front end had an ounce of grease in it. Ball joints, tie rods...all boots collapsed and bone dry. Needless to say, after greasing the front end, it was quiet as a church mouse.
1971 Chevy K20 350/SM465/NP205 |
05-17-2013, 11:46 AM | #17 |
Things did make it out of the factory that weren't right from time to time. I got this glove box door from a buddy of mine when he restored the truck. It was on an Independence city maintenance truck, it was a 1 ton NAPCO 4x4 conversion, Custom 30, 350 4 speed, and was medium green. When he first got the truck I noticed all the options were wrong, after looking at it close, it had the SPID of either the truck in front of it or behind it on the assembly line, the VIN was 1 number off. So apparently they built 1 tons and 1/2 tons together.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
05-17-2013, 01:35 PM | #18 | |
It was coming down out of paint and into trim at the beginning of second shift (4:30 pm) on Monday September 29, 1986. I followed the cab/box all the way through trim, then dropped down to the first floor to follow the engine line and chassis line build. After body drop it went straight out the back where I drove it to the shipping building myself. I left the plant at 1 am Tuesday morning and by 5 pm Tuesday afternoon it was already sitting in the parking lot at Hank Graff Chevrolet in Davison. I still had to pay the $525 destination fee to go the nine miles from the plant to the dealership. Relative to your original assertion: just like anything else we had good days and bad days; good workers and bad workers. But most of the folks were pretty gracious when they saw you following your own car/truck down the line. This truck has been a daily driver for 27 years, with 200k miles on it. So it's been a pretty good truck for being a "Monday build".... K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-17-2013 at 02:03 PM. |
05-17-2013, 01:37 PM | #19 | |
It still happens. Getting out of sequence (whether stickers, or VIN stamp, or axles, etc) is a huge mess because it usually doesn't affect just the vehicle you are looking at - you usually have a whole line full of 'em. The line doesn't stop for that so you have to expend one or two workers to go fix the mess while you keep everything else running (and pray nothing else goes to crap in the meantime). In fact we used to have a library of various tire/wheels set aside at the install location so that the matching tire/wheel could be installed on a wrong axle - all to keep the line moving. The wrong axle would be repaired "out back" (meaning "Heavy Repair"). Wish I had a dollar for every truck that was a Chevy on one side and a GMC on the other.... (lol)
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-17-2013 at 01:51 PM. |
05-17-2013, 01:59 PM | #20 |
**Warning - shameless self promotion follows**
By the way, my build/intro thread linked below has about 27 pages of stories, experiences and conversation (for anyone who might be interested). "My Pontiac Story" is my biography/autobiography about growing up in a GM family and racing factory sponsored Pontiacs (if you like mid 60's Pontiacs - approx 11 pages of stories and recollections). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-17-2013 at 02:21 PM. |
05-17-2013, 02:06 PM | #21 |
Location: Formerly MD and San Diego, now loving life in Arizona
Never had a serious issue, but did take delivery on a 1990 minivan that had specific options on the window sticker that were paid for during the purchase. Didn't do a real good look-over when taking delivery and found out weeks later that the rear window defroster (listed on the window sticker) was not fully installed. The correct glass was there, but part of the wiring harness and the dash controls were never installed. Just blanking covers/trim pieces. Dealer didn't believe me at first, but did fix the problem after they researched it.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
05-17-2013, 02:55 PM | #22 |
(lol)[/QUOTE] HAHA, a buddy of mine works for a local Chev dealer, they had a Colorado ON THE SHOWROOM FLOOR that had Colorado on the left door, and Canyon on the right..... so, not only did it make it past the plant inspection, it made it off the truck, into the detail bay, and had been parked on the floor for a couple of weeks before my buddy noticed it. (and he is a parts guy, so he's not out on the showroom very often...)
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
05-17-2013, 06:37 PM | #23 | |
http://forums.performanceyears.com/f...d.php?t=556607 K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-19-2013, 12:16 PM | #24 |
05-19-2013, 01:08 PM | #25 |
I built it
well that explains alot.. my truck is a fremont truck
