Old 05-16-2013, 07:18 PM   #1
dkauffman05
dkauffman05's Avatar
sendijg unit?
Im about to start a lq4 swap into a 1986 k-10. Will a 87-91 efi sending unit fit in the 86 non efi tank? I wanted to go that rout with a walbro pump in ths 87-91 sending unit if possible.
dkauffman05 is offline   Reply With Quote
Old 05-16-2013, 10:57 PM   #2
ls1nova71
ls1nova71's Avatar
Re: sendijg unit?
It will fit the tank, but the '86 tank isn't baffled, so you may have fuel starvation issues when doing some 'spirited' driving when the fuel level in the tank gets low.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-17-2013, 08:52 AM   #3
homemade87
Re: sendijg unit?
I run the one without the baffle for years. When about 1/4 tank and hard brakeing at a stop light the engine would stumble. When the fuel got lower the engine would die. I had to keep the fuel level up to prevent this. If I had it to do again I would put the baffle tank in to save some aggravation. Not to mention saftey concerns in traffic if your engine stalls.
homemade87 is offline   Reply With Quote
Old 05-17-2013, 12:49 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: sendijg unit?
I tell people this all the time. Tank foam can make life easier if you have no baffles. If you can get into the take through the sending unit hole, you can usually fit a few blocks of tank foam.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-17-2013, 07:34 PM   #5
jorgensensc
jorgensensc's Avatar
Re: sendijg unit?
If you get the 87 tank it has baffles.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-17-2013, 07:43 PM   #6
homemade87
Re: sendijg unit?
The 87 tank is what I use know. I just did a 5.3 swap in my 82. Solved all issues.
Old 05-17-2013, 09:24 PM   #7
jorgensensc
Re: sendijg unit?
I have been reading alot on this. If you use an 87 25 gallon tank you can use a 92-94 s10 blazer with a 4.3 CPI sender. If you use the bigger tank you may be able to just add the 4.3 CPI fuel pump to the stock 87 sender. I was trying to figure out how to make this work for me, but I need the sender to talk to the ECM with the level and 5 volt reference. And I need it to be the newer vehicle ohmage. I'm trying to figure out a way to use a newer clip on float assembly on the older sending unit.
Old 05-18-2013, 07:52 AM   #8
ghettoluxury
ghettoluxury's Avatar
Re: sendijg unit?
jorgensensc
your best bet would be to use the stock pump assembly from the engine you have in a 72 suburban or blazer tank. They did it in this episode of Trucks! http://www.powerblocktv.com/episodes...ls-engine-swap
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-18-2013, 06:33 PM   #9
dkauffman05
Re: sendijg unit?
Anyone know what size fittings are on a 87-91 fuel sending unit ? And how I can adapt them to a-n fittings.
