Throttle Linkage
I need to build a new linkage to my carb on my 70 with a 350 and an edelbrock carb. What have you guys used for this? I cant seem to find anything. Im looking for something like this that I found in a pic that 68Stepbed had on his truck. Can anyone point me in the right direction.
1970 SWB Build |
Re: Throttle Linkage
I used a piece of 1/4" threaded rod and 2 heim joints off Ebay. Less than $20 and works great, looks pretty much like your photo.
You can see the one end on page 4 of my build thread.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
![]() Join Date: Aug 2008
I read somewhere on here where guys would use the shift rod off a Harley that most of the Hog guys discard for one with more "bling".
Can anyone tell me what the distance is from the linkage on a Qjet carb to the pedal rod at the rear (ie how long does the rod that connects the two need to be)?
Quit if it's not FUN!!!
That's basically what I did. Bent a slight offset in the rod to make it line up with the Q-jet. Once I got the length right, I slipped a piece of rubber hose over the threade rod to "clean" it up some.
I used a 3/16 thick piece of aluminum and parts from one of the cheep $10.00 throttle bracket kits
Fuzzy |
I just installed this linkage from Jegs. Fits and works great.
JEGS Performance Products 15795 Adjustable Throttle Linkage Rod ![]() Posted via Mobile Device
1970 C10 Short Stepper with 71/72 front clip. |
I agree with heim joints and all thread. Just purchase more length than you need and cut it down. Someone else's measurements are to their preference with their particular joints. Pedal feel, bends, and things in the way at WOT will influence your specific rod length. Good luck.
Posted via Mobile Device |
#9 | |
Thanks everyone for your help. This is the only thing keeping me from driving my truck, so Im a little eager to get this taken care of.
1970 SWB Build |
#10 | |
![]() Join Date: Oct 2012
we used a floor shifter linkage rod on dads
