Old 05-16-2013, 10:02 PM   #1
corvettejim1968
corvettejim1968's Avatar
decode my carb please
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 05-16-2013, 10:12 PM   #2
losthope
losthope's Avatar
Re: decode my carb please
wow wow back this carb id train up a minute! little more info would help...brand, 2bbl? 4 bbl? ...the tag you took a picture of doesnt always tell you what the carb is or will tell you at all....alot of the time if its been rebuilt by a carb shop they put those tags on and by the looks of that tag its not from factory.....most of the time you I.d. a carb by stamped numbers on the carb somewhere ....edelbrock and carter 4bbl carbs usually have the numbers stamped in the right front lower mounting flange....holleys sometimes have them stamped into the air choke horn......could you give a little more info on brand, and maybe look for any stamped numbers on the carb, maybe a full view picture of the carb..
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 05-16-2013, 10:15 PM   #3
losthope
losthope's Avatar
this is what came up typing the number into google looks to be a ROCHESTER SINGLE CARBURETOR for a 6 cyl engine and that tag is from a rebuild kit:
http://www.carburetion.com/CarbNumbe...Number=7026019
http://www.carbkits.com/catalog/details/858
http://www.ebay.com/itm/ROCHESTER-SI...-/330908404095
http://www.carb-x.com/domestic-carbu...r-carbs/11-68b
Timmy D.
Old 05-16-2013, 10:36 PM   #4
corvettejim1968
1965 c10 230 six . im not sure what tranny it cam with but im pretty sure a powerglide. it has a th350 now. the engine was rebuilt in 1980 so the original valve cover has been replaced. the truck has 107,000 miles on it.
Old 05-16-2013, 10:40 PM   #5
losthope
losthope's Avatar
its a single bbl Rochester for 1963-1967 chevy/gmc
Trans: All
Engine: 6 Cylinder Engine
and heres the OEM Rochester Part Numbers for that style carb:
Rochester 7016322 , Rochester 7023011
Rochester 7023017 , Rochester 7023021
Rochester 7026017 , Rochester 7026019
Rochester 7041860 , Rochester 7023013
Rochester 7024004 , Rochester 7024009
Rochester 7026011 , Rochester 7026029
Rochester 7027009 , Rochester 7027011
Rochester 7027029 , Rochester 7036009
Rochester 7037009 , Rochester 7041861
Timmy D.
