Old 05-16-2013, 10:20 PM   #1
meatwagon83
meatwagon83's Avatar
headlight modification
i put silverstar sealed beams and relays in my headlight harness today, and my headlights are SUPER FRIGGIN BRIGHT!!!!!! thanks for the ideas guys!!
that is all.........andy
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 05-16-2013, 11:49 PM   #2
texas gmc
Re: headlight modification
I'd like to do mine.
texas gmc is offline   Reply With Quote
Old 05-17-2013, 12:48 AM   #3
bilfman
bilfman's Avatar
I did the same with mine using hella's from amazon. 34 bucks a pop , bulb included. Sourced relays locally for $7. Wow what a difference over the old sealed beams. I will probably put silver star bulbs in, later down the line. If you do plan on this getting an old harness from a wrecker lets you maintain your stock one. Do your relay hacking on the wrecker harness and just tap into your truck one with some spade connectors. That way you can be back to stock in seconds.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 05-18-2013, 02:36 AM   #4
izzy_Britton
izzy_Britton's Avatar
I am interested in this mod, i think? is this similar to what LMC offers as their headlight wire harness for direct connection to the battery or some such thing? please share the info on this mod. thanks.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 05-18-2013, 11:55 AM   #5
meatwagon83
its the same mod i just got some relays off the firewall of a 91 suburban and made my own harness, i got a diagram off the 73-87 truck site, im sure there is one on this site too, to many guys here have done it!
Old 05-19-2013, 03:12 AM   #6
izzy_Britton
Any body have a link to the mod details? I have been looking at this picture for the last couple hours and i am totally baffled as to where the connections are actually made other than the obvious headlamps and battery.
Any further info would be greatly appreciated.
I have a 86 that i will be converting the front over to 89-91 and would love to do this mod while i have it apart.
-Izzy
Old 05-19-2013, 03:25 AM   #7
83GMCK2500
Izzy...where are you lost? The OEM setup routes all of the current that is delivered to the lamps through the dimmer switch and the headlamp switch. That circuit remains unmodified, it is used as the "low current" or control circuit for the relays. The high current side of the relays connect to the junction block on the firewall, or other more direct path to the battery and to the lamps.
I think the connections that you are looking for are the 11/150 and 11/12/150, where they used to route power directly to the headlights they are now used to control the relays.
We do have a vendor that sells a rather impressive harness using high quality components: HERE
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 05-19-2013, 11:00 AM   #8
meatwagon83
yup, thats the diagram i used! i was going to buy that harness but i didnt have the benny to blow on it!
Old 05-19-2013, 04:48 PM   #9
wraprail
wraprail's Avatar
As I posted in the other thread, pole 85 on the relays and circuit 150 at the headlights are chassis -ground. The do not need to be connected together as is shown on the diagram.
Only one fuse (30a) is needed. Split the wire or jumper between pole 30 on the relays.
You can install your relays on the firewall where the harness connector is.
Cut the harness right there and splice in your relays. There is plenty of slack in the wires.
The relays are marked on the underside
To make it easy, find the high beam hot wire (use a test light) cut it, the switch side goes to 86 and the highbeam side goes to 87.
Lowbeam hot wire do the same thing on the other relay. 86 and 87
hook both pole 85 together and ground.
Hook both 30 together, then to fuse and power. Use at least #12 wire.
All the other wires are factory and should already be there. Nothing more is needed.
Thats it.
wraprail is offline   Reply With Quote
Old 08-03-2013, 05:31 PM   #10
izzy_Britton
I am revisiting this thread and while i am working under the hood on a few things.
after reviewing the info above i think i understand most of the wire routing now that i have a relay in my hand.
My new question is about the relays themselves.
first what relay is recommended for this mod?
the relay i have in my hand at the moment is a BOSCH 0 332 204 150 The only difference between this relay and the pin-out imaged is that there is an extra pin, 87a
thoughts?
-Izzy
Old 08-03-2013, 08:04 PM   #11
meatwagon83
i dont remember what mine are, like i said i got them off a 91 subs firewall buy the distributor
Old 08-03-2013, 08:20 PM   #12
lilpoindexter
lilpoindexter's Avatar
Has anyone tried the LMC headlight harness for single headlights? i'd like to try this on my '78, but some of the LMC parts i've recieved have been hit or miss. The dim yellow lights just ain't doing nothing for me at night.
lilpoindexter is offline   Reply With Quote
Old 08-03-2013, 08:39 PM   #13
izzy_Britton
Are you talking about the great big relays that are bolted to the firewall to the passengers side of the distributor? arent those for the fuel pump and something else? i didnt think they would work, they seemed like they were way wrong when i looked several weeks ago. maybe i seen something different?
-Izzy
Old 08-03-2013, 08:40 PM   #14
izzy_Britton
Basically that is exactly what this mod will do for pennies on the dollar compared to the LMC version. just DIY.
-Izzy
Old 08-03-2013, 09:58 PM   #15
meatwagon83
-Izzy
those are the ones i used, they work great! i have a buddy that used the same ones on his 79 and they work great as well
Old 08-03-2013, 10:03 PM   #16
izzy_Britton
OK THEN! monday i will aquire these and start my harness mod. maybe i was looking at something different or maybe it just didnt click in my head when i was looking at them. I know that these are the fuel pump relays and such and are about 90$ (or used to be about 90$) at the stealer, so maybe that is why i shied away from them... who knows.
but now i can start the mod.
-Izzy
Old 08-03-2013, 10:45 PM   #17
anubisani
anubisani's Avatar
I WAS thinking of buying this setup
http://www.ebay.com/itm/330788750080...84.m1436.l2648
anubisani is offline   Reply With Quote
Old 08-03-2013, 11:12 PM   #18
wraprail
wraprail's Avatar
thoughts?
-Izzy
87a is normally closed (where 87 is normally open) so you would just leave 87a open..( not connected)
The Bosch relay you have is ideally suited for this applacation. Its the same relay the aftermarket harness uses as well as most car alarms use.
Old 08-03-2013, 11:45 PM   #19
izzy_Britton
Thank you for the insight wraprail. I found these in a square, 4 of them and a little 10 wire module all wired together, screwed to the back of the steering column/dash plate. I thought at first it was an alarm or something but they are all wired together, in series (i guess that is what i would call it). I wondered if it was a DIY heardlight or window motor thing.
so yeah i have 3 relays and 3 wire connections. ready to rock and roll then.
thanks again wraprail.
-Izzy
Old 08-04-2013, 12:27 AM   #20
bojak
bojak's Avatar
Yes I just did the single headlight harness from LMC with new headlights and it is great. Really simple to do and the results(especially how terrible it was b4) are awesome. This was money well spent IMO.
bojak is offline   Reply With Quote
Old 08-04-2013, 01:32 AM   #21
Redcap
I like this idea.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 08-04-2013, 10:13 AM   #22
meatwagon83
however you do it this is a worthwhile modification, after i did this my brights light up signs more than half a mile away! no joke!
Old 08-04-2013, 11:10 AM   #23
wraprail
wraprail's Avatar
I agree 100%. This gives and a very noticable improvment for very little cost no matter how you do it.
Just don't follow clint's advice. lol
Old 08-04-2013, 03:11 PM   #24
izzy_Britton
Who is Clint and what was the advice he gave that i should not follow?
also the ebay wire harness looks like a good price, hard to say how well it is constructed, but looks good. my only question about the above mentioned ebay item is...
WHERE the heck does this plug into?
I do not recall seeing anything where that would plug in under my hood. maybe this is just a generic photo and the harness for our trucks is slightly different?
-Izzy
::Edited to reduce photo size::
Old 08-04-2013, 03:26 PM   #25
izzy_Britton
Your talking about THESE right?
These are from a 89 and 91 suburban. they are a 5 pin relay with each pin labeled A - F (there is no pin B however).
I now have these and a set of the 5 pin bosh relays, I like the GM relays because they are weather proof and look factory if i can use them. do you know the PINOUT for these? are these the correct ones that you mentioned?
-IZZY
