05-17-2013, 10:29 AM | #1 |
stoplight switch
Is there a unniversal stoplight switch you can use with 4 spade connectors for the lockup to the 4L60 transmission? I got one from the parts store but would need the harness and brackets for the origional vehicle.
05-17-2013, 05:37 PM | #2 |
Re: stoplight switch
i'm sure you can get a switch but any factory switch will need a bracket
this is what i did with a $5 relay to control my trans and cruise control using the 87a terminal your trans will have power until you touch the brakes same as the switch your trying to get/make work
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-19-2013, 08:51 PM | #3 |
Thanks ogre, I'm sure with a little help I can make that work. I'll be glad when it's all wired.
