05-17-2013, 10:54 AM | #1 |
1988 serpentine
Question: Will this serpentine system from a 1988 1/2 ton 350 Silverado work
on by 1970's small block? It's not the aluminum type brackets, as you can see.. |
05-17-2013, 02:56 PM | #2 |
Re: 1988 serpentine
05-17-2013, 03:05 PM | #3 |
Moderator
Re: 1988 serpentine
It will work, even without seeing it. You need to change your non-SP water pump to the SP waterpump.
05-17-2013, 03:14 PM | #4 | |
Re: 1988 serpentine
My bad, forgot the photo....it's sideways but hopefully You guys can see what I mean... Posted via Mobile Device |
05-17-2013, 03:21 PM | #5 |
Re: 1988 serpentine
As jay mentioned- yes it will work, by changing out the water pump to a reverse rotation type. Also, you may need to switch out the hose fitting in the back of the power steering pump, if you have the old style flare fitting hose ends.
05-17-2013, 03:26 PM | #6 |
Re: 1988 serpentine
It should work and be the same as long as you have threaded holes on your 70's heads. check this helpful link... http://www.carcraft.com/techarticles...e/viewall.html
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
