05-17-2013, 01:50 PM | #1 |
Drop spindle with air bags
Im trying to decide if i want a static drop or to bag my truck. If i do a static im looking at 5.5 in front and 8 in the back, with springs and drop spindles. If i bag it my question is can i get the same drop with out using drop spindles.
Im only using my truck normaly day driving and cruises. Not really looking for a road course truck. Thanks |
05-17-2013, 01:55 PM | #2 | |
67-72 parts collector,…
Re: Drop spindle with air bags
You need drop spindles either way.
05-17-2013, 03:57 PM | #3 |
So my question then is why bag the truck if i can get the same amount of lowers with the springs and spindles.
05-17-2013, 04:25 PM | #4 |
Spindles and springs will get your truck's front a-arms about 2" off of the ground.
Bags (and spindles) will allow you to set your a-arms on the ground. Spindles help with front end camber. Plus they are a cheap 2.5"-3" drop.
05-17-2013, 04:49 PM | #5 |
Because with bags you can raise it up so you don't lose your a arms on the speed bump.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-18-2013, 03:20 AM | #6 |
Bags will ride smoother then a metal spring and your ride height is adjustable on the fly.
05-21-2013, 11:47 PM | #7 |
Bags ride awesome. My truck rides like my buddy's new Escalade. Plus you can adjust the height. 2" off the ground would be a pretty aggressive static drop lol
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
05-23-2013, 12:31 PM | #8 |
looks like im going to bad it. i do have a one more question. I see people cutting the spring seat out of the lower control arm and some just installing a piece of metal over the lower and bolting the bag to that. what is the best way.
05-23-2013, 02:10 PM | #9 |
that will limit the drop. Many people cut a hole in the arm and use 8-9inch pipe to get the bag to sit lower.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
