Old 05-17-2013, 04:03 PM   #1
HzEmall
HzEmall's Avatar
Spindle / Tie Rod Question
73-87 Spindles (I have the CPP Mods)
What is the diameter of the Tie Rod hole?
Is it tapered?
If so, what is the degree of taper?
Thanks guys.....
Tim Baillie
Installer/Designer/Fabricator
Trick Factory Customs
Company - www.trickfactory.com
Personal - www.hzemall.com
Instagram - @hzemall
HzEmall is offline   Reply With Quote
Old 05-21-2013, 08:54 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Spindle / Tie Rod Question
Sorry,... I can't help on the taper size of the spindle hole.
It is definitely tapered.
What year truck are you working on?
I would swap tie rods or spindles to get the correct fit,... before I would ream the tie rod hole in the spindle.
Keith
Convert to disc brakes.
Old 05-21-2013, 10:13 AM   #3
HzEmall
HzEmall's Avatar
Mine is a 79
Tim Baillie
Old 05-21-2013, 11:45 PM   #4
Square_78
Square_78's Avatar
The modular spindles take a 73-87 tie rod and ball joints.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 05-21-2013, 11:55 PM   #5
HzEmall
HzEmall's Avatar
I know that, that isn't what I was asking but thanks.
Tim Baillie
Old 01-25-2014, 07:20 AM   #6
Suburban_Tyler
Suburban_Tyler's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=447061
http://67-72chevytrucks.com/gallery/...4016_large.jpg
Is this the information your are looking for? This guy used 1.5" per foot (7degree) in his build to retain the stock tie rod ends.
Suburban_Tyler is offline   Reply With Quote
