05-18-2013, 02:59 AM | #1 |
Crown Suspension 3" Drop Spindles ??
I found these spindle on Ebay for $205 not a bad price. But I have never
heard of them. Wondering if anyone hear can give some feedback good or bad. http://compare.ebay.com/like/2710978...ypes&var=sbar#
1952 Chevy Pick Up 1962 Chevy C10 Short Bed 1963 Chevy C10 Long Bed 1986 Chevy Silverado Short Bed 2004 Chevy Suburban-wifies ride |
05-18-2013, 05:42 PM | #2 |
Re: Crown Suspension 3" Drop Spindles ??
cant speak for crown but i got my dropped spindles from these guys
http://www.ebay.com/itm/73-87-C10-w-...ht_1289wt_1399 about same price, but with free shipping they sell belltech blems, the only thing i saw blemed on mine was the painted/powdercoated finish had a couple bad spots other that that looked great but i have not installed them yet
1969 C10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=580422 1981 C10 SWB 1995 ECSB Bagged |
05-18-2013, 09:12 PM | #3 | |
They look exactly the same. The price is the same as well. Thanks for the info I might just go with your vendor.
05-21-2013, 11:35 PM | #4 |
Watch out when running 15" wheels with 3" drop spindles. Doesn't always work so well. Wheels will rub on the lower control arms.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
05-22-2013, 02:07 AM | #5 |
i second this. just put 2.5" drop spindles on my 67 and my 4.75 back spaced 15in wheels dont work. they DO rub on the control arms. i did find some old real shallow back spaced steel wheels that fit but they are super narrow(like 6in's wide with a 3in back space, they look super stupid but they work). no big deal cause im not keeping those 15's anyway, but it did put me in a weird spot with getting my truck to the alignment shop.
'67 2wd LWB 350/4speed. |
05-22-2013, 05:18 AM | #6 |
67-72 parts collector,…
You can run a 15" wheel with a 4" (max) backspacing with any 2.5"-3" drop spindle.
All you have to do is slightly trim the lower a-arm. You will also need to tweak the brake hose at the caliper, to clear the upper ball joint. It's been this way since the 80's. Nothing new here.
05-23-2013, 12:56 AM | #7 | ||
Thanks lolife I will make sure to check the back space of the wheels prior to making the purchase.
05-23-2013, 03:44 PM | #8 |
