![]() Join Date: Oct 2007
4" Lift Springs/4:10 Rear Axle
New 4" Lift Springs only used to roll around bare frame...Going back to stock springs. This is for springs only...no hardware or blocks. $400.00 prefer local pick up but will ship on your dime if needed. 2 1/2" wide. REVISED...SEE POST #8
HO52 4:10 Drum to Drum...Got from another board member but going a different direction...$250.00 - No Shipping...Local Pickup only. Located in Gettysburg, PA and travel the NE from PA to MA so might be able to arrange delivery for small fee. Alan Last edited by My72BB; 05-21-2013 at 07:29 AM. Reason: Revised Spring portion |
![]() Join Date: Oct 2012
Re: 4" Lift Springs/4:10 Rear Axle
Front or rear springs? What brand?
Thanks. Jeff Posted via Mobile Device |
Front and Rear Rancho springs.
So do these lift the front and the rear by 4" thereby leaving the rear a couple inches lower than the front like factory? Is that why the picture shows some blocks as well?
Do you have part numbers as I can't find any springs on Rancho's site that fit these trucks. I also need to make sure these will fit a '71 Blazer? Thanks. Jeff Posted via Mobile Device |
I don't have P/N's...When I purchased they were sold as 4" lift springs...All I can tell you. Don't know about lower on one end or the other.
These are mounted to a 1972 K20 as you can see in the pictures. If Blazer springs fit a K20 or vice versa then these will fit. Springs are 2 1/2 wide as I had mentioned and rears are 52" long. I am taking these off and putting factory springs back on the truck with no mods. Alan |
OK, I'll check the application when I get home. I did note on Rancho's site that the 4" kits accomplish the rear lift with blocks or springs and blocks. Did the blocks tht are mounted on the rear springs in the pictures come with the springs? Can you take a profile picture of the frame before you tear it down so I can see the rake of the frame rails?
If you decide that you would ship just the third member from the rear let me know. I need a 4.10 third member to go in my HO52.
69 C20 - work in progress 91 Z28 - the weekend toy 05 Burb 2500 - DD and big block power |
496BB - Sent you a PM.
Revision in Springs...Fronts only with 4" blocks for rear are available for $300.00. Had issues with spring bolts on front springs here is what you are getting. 4" lift springs for the front with new OEM style bushings just pressed in yesterday on front of spring with new OEM style bushing and hangars with bolts for rear of spring. These are Rancho brand but now do not have the Poly style bushing in the springs. The picture is comparison of this spring next to factory spring. $300.00 for front springs with 4" lift blocks for rear. Prefer pickup but will ship on your dime if needed. |
I'm going to pass.
New PM sent on this older posting. kcd
