Old 05-18-2013, 11:29 AM   #1
cfan10
cfan10's Avatar
Cool Steering gearbox...removal please, help
Someone please tell me what I’m doing wrong, I am hammering on the idler arm to disconnect it from the not sure what it is called coupling, maybe?
I’m trying to replace my steering gearbox on my 84 10 and this is the last thing to do to get the thing apart…it is giving me royal h3ll, I have it up some but not enough to remove the threaded bolt is still on the smooth part, hope I'm making sense…is there a tool I can rent to make this easier on me. I gave it a bath in wd-40 and its still not off, any tips/tricks to remove this thing?
As always all advice/experience is greatly and sincerely appreciated. Thanks in advance.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 05-18-2013, 11:58 AM   #2
geezer#99
geezer#99's Avatar
Re: Steering gearbox...removal please, help
Take a pic!!
Old 05-18-2013, 12:21 PM   #3
mrolds88
Presuming that you are referring to the arm on the box, you will need a puller. One like this.
http://shop.advanceautoparts.com/web...man+arm+puller
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-18-2013, 03:56 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
-Remove big giant nut holding pitman arm in place
-Use pitman arm puller to remove arm from splined part of steering box shaft. Sometimes they won't come completely off and out of the way but they will be obviously loose from the splines.
-remove the two hoses from the top of the box
-remove the pinch bolt from the steering coupler. It will take a 7/16 wrench or socket, 12 point only. Tap steering shaft coupler upwards off of the box input shaft.
-remove four mounting bolts (3/4 inch socket) holding box to frame.
-lift box slightly if needed to fully disengage the pitman shaft from the pitman arm.
-clean up spilled fluid.
sent from my iPad while sitting at the Tampa airport waiting to go back to Texas
Old 05-21-2013, 01:47 AM   #5
Stoney
Farm Truck
Stoney's Avatar
Caught that....
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 05-21-2013, 03:29 AM   #6
zaccaglin
zaccaglin's Avatar
When using the pitman arm puller invest in a decent one from napa. The cheap one that autozone sells will bend easily. Also hitting the pitman arm with a propan tourch helps as well. Made replacing the steering box on mine 10x easier.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
