Old 05-18-2013, 05:16 PM   #1
LEEVON
Moderator
LEEVON's Avatar
A/C Clutch Pressure Switch
It got freaking hot today...wasn't prepared for that. Ambient outside temp here was about 88 degrees and I've gotten really soft apparently. So I swung by the parts store and got some R134a.
I don't know the history of the a/c system in my truck, just that it's all intact and the compressor was unplugged. I figured I'd take a chance, and I realize this isn't the best way to get a reliable working system. It may take a flush and new components in the future. I also have some R12 stashed just in case. So I plugged in the compressor, started the charge and the clutch wouldn't cycle. I jumped the compressor switch, it cycled and low and behold worked (for now). I could not get the clutch to cycle on it's own with the switch plugged in so I assumed the low pressure switch was bad and bought a new one.
Can I change the switch while the system is charged?
Thanks!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 05-18-2013, 05:55 PM   #2
Troy 82
Re: A/C Clutch Pressure Switch
yes. Just unscrew & screw the new one on.
Troy
1982 Silverado
Troy 82 is offline   Reply With Quote
Old 05-18-2013, 05:57 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
You shouldn't have any issue, There's a schrader valve under it to hold refrigerant in. Just screw the old one off quickly and screw the new on quickly.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
