Manual trans question
The power team chart says I have a ch465 4 speed.
I thought I read somewhere it was a M20. Is there a simple id I can look for? I went to the heritage site and indication there is same power team chart. Any suggestions, comments? Many thanks. Cheers, Nim Posted via Mobile Device
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
Re: Manual trans question
Pretty sure have an sm465....pics would be nice..
Posted via Mobile Device |
The CH465 is an internally shifted wide ratio four speed transmission with a low first gear.
It is listed as RPO M20 on the SPID. It is not the same as the externally shifted car transmission by the same name. In the factory service manual it is the Muncie Four Speed trans.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thanks folks!
The m20 was on my spid. I figured it out after scratching my head for a half hour. Tim- many thanks. As always Cheers Nim Posted via Mobile Device
M20 is just the option number for a particular platform, in your case, C/K series trucks. M shows transmission and 20 is GM's code for wide ratio 4 speed. In a performance car, it would have been the 2.52 first gear Muncie aluminum case side shifted trans. In a base model car it would have been a Saginaw side shifted iron 4 speed. And in a truck, it is the iron case top shifted SM465 which is also referred to as the CH465 in some literature, mostly early stuff.
Synchro-Mesh is what consensus seems to be that SM stands for, but who knows? It is also known as the 117mm 4 speed FWIW.
