Old 05-19-2013, 08:01 AM   #1
956LOUIE
Ls swap a/c questions
I know this is prolly not the first time someone has asked this
Truck 57 chevy with no limit engineering front and rear airride suspension
Engine 2002 chevy 5.3L with Nelson performance stand alone wire harness with an original PCM not aftermarket
I am in te process of perfecting all the details to my frame to perfect all the details on the frame and want to make sure before i have to do any modifications to the frame that the original compressor & brackets will work and function correctly i also want to run the whole ac unit as an assembly from the 2002 p/u
Questions
Is this possible ?
Has it been done ?
What special things would i need ?
Is this the best thing to do ?
What would be the most cost effective ?
What problems should i look out for ?
956LOUIE is offline   Reply With Quote
Old 05-19-2013, 08:04 AM   #2
956LOUIE
Questions
Is this possible ?
Has it been done ?
Old 05-19-2013, 11:32 AM   #3
truckdude239
truckdude239's Avatar
Re: Ls swap a/c questions
moved tot eh lsx swap section where you will get better answers
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-19-2013, 06:35 PM   #4
mrhurt73
ok
i dont have a no limit front end, but another brand, depending upon you motor mounts you very well could have to cut the pass side frame for clearance.
and learn from my mistakes, buy a new or rebuilt compressor, mine came with junkyard motor, charged up just fine, two days later seal inside compressor blew and let everything out.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
