Old 05-19-2013, 02:07 PM   #1
madmoggy
Shocks/dampers
Hi I bought some shockabsorbers front and rear for my 70 c10
fitted them but but am disappointed as the truck wallows around as bad as before.
the shocks are supposed to be heavy duty gas,also if I bounce the back it bounces for two or three times then goes stiffer but the front is very soft.
any ideas guys what I should be fitting,I don't want the front wallowing into bends.
many thanks Si
madmoggy is offline   Reply With Quote
Old 05-19-2013, 08:35 PM   #2
Indyuke
Re: Shocks/dampers
Bilstein 4600 series shocks are the best for our trucks. These will last you for a VERY long time... they don't go bad very often.
Monroe if you want a softer ride. They also don't last very long.
Rancho if you want a stiffer ride. These don't last long either.
Mixed reviews on KYB GR2 and ExcelG. They're a little stiffer than stock, but soften up with use. Some people have success with them not going bad right away, some don't.
After you pick a brand, you'll have to tailor you purchase to whether your truck is a 1/2 or 3/4 ton, lowered, whether it has HD springs or a sway bar up front.
I've been told a 1/2 ton truck with rear HD springs, front sway bar and at stock height with bilsteins will ride really sweet... not wallowing at all, and maybe slightly firmer than when they came from the factory. It will also corner well and haul a good load.
Indyuke is offline   Reply With Quote
Old 05-19-2013, 10:00 PM   #3
Lee H
Lee H's Avatar
Re: Shocks/dampers
Yup, I run bilsteins on everything I own. A good set of sway bars will also help out.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-20-2013, 01:21 PM   #4
madmoggy
Thumbs up Re: Shocks/dampers
Thanks fellas sorry I haven't got back earlier ,I have just got in from work
Old 05-20-2013, 02:02 PM   #5
madmoggy
Re: Shocks/dampers
Just looked at your build thread,superb truck,you must be very proud,well done
Old 05-20-2013, 02:37 PM   #6
Lee H
Lee H's Avatar
Re: Shocks/dampers
Thanks!
Old 05-20-2013, 02:57 PM   #7
cdowns
cdowns's Avatar
Re: Shocks/dampers
has this truck been lowered? if yes and shock relocators not used , you will lose alot of the effective shock rate with them being laid down
Old 05-20-2013, 03:32 PM   #8
leftybass209
leftybass209's Avatar
Re: Shocks/dampers
While it's most likely shocks, a highly worn suspension could offer up some similar problems. Badly worn springs don't give even the newest shocks a very good base to perform their job correctly. Just some food for thought. Good luck in your search for the culprit!
leftybass209 is offline   Reply With Quote
Old 05-20-2013, 04:02 PM   #9
madmoggy
Thanks,will check the suspension through,the truck is not lowered at the moment but I will be lowering the front so probably will wait until I do that and check everything out then get some decent dampers.
Have a disc brake conversion to do on it as well .
Old 05-20-2013, 07:02 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Shocks/dampers
Another good shock is KYB Gas-A-Just. Firmer than stock without being harsh, will soften a bit in time and lasts a long time. Ditto the above advice for a sway bar.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
