Old 05-19-2013, 05:30 PM   #1
tmc1986
hub centric?
i understand what the difference is between hub centric and lug centric wheels. my question is: if i have a 3in hub diameter and i buy wheels with a 4.25in center bore diameter, is it ok to run them without the center bore fitting on the hub? i know the hub is supposed to take the weight but can i get away with the lugs doing all the work like a lug centric wheel? i tried to search for an answer but keep getting conflicting info. the wheels are raceline 136 maxim 20x8.5 if anyone was wandering. the rotors are 6 lug ECE for the 71' and newer. thanks in advance.
'67 2wd LWB 350/4speed.
tmc1986 is offline   Reply With Quote
Old 05-19-2013, 08:16 PM   #2
LONGHAIR
Re: hub centric?
That is the exact definition of lug-centric....
Many aftermarket wheels are that way. It allows them to fit more vehicles with the same bolt-circle, but have different hub diameters.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-19-2013, 09:29 PM   #3
tmc1986
Re: hub centric?
Ok thanks. Wheels are expensive to order the wrong stuff. Even if I can return them it's a pain in the butt.
Old 05-19-2013, 10:14 PM   #4
71swb4x4
71swb4x4's Avatar
Re: hub centric?
I think the key is to get lug nuts that are for those wheels.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
