fouling plugs???
What causes spark plugs to foul out?
RIZ ![]() |
Re: fouling plugs???
Burning oil is usually the culprit.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Unburnt fuel as well. I had that issue when I mistakenly put too cold of a plug in my truck. I now use the Autolite 24's and they do really well.
Just here to tinker
![]() Join Date: Jun 2008
I agree with above and both statements have many facets to them.
Burning oil could be caused by: worn rings, worn valve guides, wrong type of oil used, low compression. Fouling from fuel could be caused by: ignition timing, choke not operating properly, idle mixture screws too rich, low compression, dirty cap and rotor, dirty air cleaner. These lists are not all inclusive but probably the most common reasons. Posted via Mobile Device
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
A wise old man once told me that a "cocoa brown" plug was firing correctly and not to touch a thing. RIP Charlie!
