Old 05-20-2013, 09:05 AM   #1
Rich84
Rich84's Avatar
Sway bar on a Lowered Truck
My truck did not come with a sway bar.I got one from the junk yard but was unable to remove the frame brackets. I have a 4.5 inch drop. Can I just attach the bushings directly to the frame? Might I need a lowered bracket?
Any pictures of what the bar looks like at the control arms would be helpful so I can see how it is supposed to look.
Rich84 is offline   Reply With Quote
Old 05-20-2013, 09:08 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Sway bar on a Lowered Truck
Yes you can bolt it directly to the frame.
Keith
Convert to disc brakes.
Old 05-20-2013, 09:29 AM   #3
Big Dawgs 86
Big Dawgs 86's Avatar
Go to the 67-72 google search up top of page.. And search sway bar install.. A member from this site put everything you need to know.. It really helped me out.
Working on my 2001 Chevy 1500 4x4...
Big Dawgs 86 is offline   Reply With Quote
Old 05-20-2013, 09:53 AM   #4
Rich84
Rich84's Avatar
Ya...I'm not sure why I didn't start there to begin with..Thank you TxFirefighter
Old 05-20-2013, 02:05 PM   #5
JCampbell
http://67-72chevytrucks.com/vboard/s...d.php?t=351586
Good to know about the ability to eliminate the frame stand-offs for slammed rigs. I’ve got a sway bar on a ¾ ton parts Suburban I’ve been thinking about throwing underneath Shorty. Might have to get to it this week.
JCampbell is offline   Reply With Quote
Old 05-20-2013, 02:50 PM   #6
Rich84
Rich84's Avatar
I took the one that I have off of a 3/4 ton pickup..I was expecting it to be 1 1/8" or 1 1/4", but it is 1 1/16'. I guess if it was good enough for that truck it will be fine for my little stepside.
Old 05-20-2013, 03:29 PM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Add urethane middles and leave the outside rubber. That will make Abigail difference in the bars performance
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-22-2013, 06:35 PM   #8
kevinr1970
Why leave the outside rubber?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 05-22-2013, 06:43 PM   #9
wraprail
wraprail's Avatar
And who is Abigail?
wraprail is offline   Reply With Quote
Old 05-22-2013, 06:43 PM   #10
74 stepside
74 stepside's Avatar
Or you can get these new shorter brackets for $40..
74 stepside is offline   Reply With Quote
Old 05-22-2013, 06:45 PM   #11
cory d
cory d's Avatar
they need to twist and flex. i would replace the outside ones with new rubber. they dont last forever. i was just going to put rubber pads under my bushing on the LCA but i guess i forgot lol
cory d is offline   Reply With Quote
Old 05-22-2013, 07:24 PM   #12
INSIDIOUS '86
Originally Posted by wraprail View Post
And who is Abigail?
Lol. "And it will"* phone tech is brilliant sometimes aye?
Old 05-23-2013, 05:52 PM   #13
kevinr1970
Isn't the point to eliminate as much twist and flex as possible?
2000 Tahoe Limited
Old 05-23-2013, 06:13 PM   #14
INSIDIOUS '86
Sure but you should take out the springs and go solid rubber and run no shocks.
Look at a side profile and you will see that the swaybar travels in an arc up and down. Solid mount or soft mount will make little difference other than the sway bars reaction. So go rubber so your suspension can move without the bar binding and holding it down. Much smoother ride that way.
Old 05-23-2013, 10:50 PM   #15
wraprail
wraprail's Avatar
So you are saying take out the springs and replace with solid rubber?
What kind of solid rubber?
You wouldn't need shocks I agree.
What i'm not getting is how this will ride smoother?
Smoother than what?
I'm trying to understand. Help me out.
Old 06-16-2013, 09:13 AM   #16
Rich84
Rich84's Avatar
Well I finally found the time to get my sway bar installed..what a difference in handling..it's amazing..one of the best bolt on mods you could do.
Old 06-16-2013, 10:38 AM   #17
SkinnyG
SkinnyG's Avatar
Smoother than what?
When your suspension compresses to go over a bump, the sway bar and the control are moving through different arcs.
Because of the way the factory mounted the ends of the sway bar (clamps, not really "end links" per se), they kind of fight each other. This is why the end rubber doesn't last forever.
If you run polyurethane ends, the significantly restricts the movement between the control arms and sway bar ends (they are rotating in different directions), and can introduce a level of "bind" in the suspension.
Would you notice? Maybe. If you are really discerning. Try it both ways and report back to us!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 06-16-2013, 11:44 AM   #18
Rich84
Rich84's Avatar
I went with the black poly bushings..grease fittings on the frame..I think I'll be leaving it like this..They were more flexible then I expected. The ride doesn't seem any harsher then it was before.
Old 06-16-2013, 09:11 PM   #19
86shorty
86shorty's Avatar
I know when I bought my 86, it was lowered and has a swaybar. It looks newer than the rest of the truck and I believe its all poly bushings. The truck drives like a dream. Not sure how much the swaybar plays in that though.
86shorty is offline   Reply With Quote
