Old 05-20-2013, 11:59 AM   #1
Old Crow
Old Crow's Avatar
Another temp gauge thread
OK, I checked out the 4 pages of results when you type in "temp gauge sender" in the forum and I still can't find an answer to my particular question. Lots of tips, some of which I've tried, and I still get the gauge pegging when the coolant in the radiator is only 140*
I'm about ready to install a resistor in the line to the sender and be done with it. Only thing is, I'd kinda like to know the resistance the gauge is supposed to see to help me select a resistor. Can't find any specs on the '59 temp gauge to see what resistance the gauge is looking for.
Anyone know for sure?
Old Crow is offline   Reply With Quote
Old 05-20-2013, 03:22 PM   #2
_Ogre
_Ogre's Avatar
Re: Another temp gauge thread
you need a stock sender to work with the stock gauge
i suspect you have a newer sending unit
i believe stock is 30 ohm resistance, newer ones are 70 ohm
but wait for someone else to confirm that before you tear into anything
your coolant sensor should look like this
shop air compressor timer
Old 05-20-2013, 04:37 PM   #3
Old Crow
Old Crow's Avatar
Yeah, that's what it looks like.
I ordered it(from O'reilly's)for the '59 truck with a 8 cyl(as the truck was originally). When I removed the sender to clean the teflon tape off of it(not my work, I knew better already)I measured the resistance of the sender and it's a bit over 500 ohms cold.
No wonder the gauge reads wrong!
Who'da thought...bad parts right out of the box?
We've got a '57 Bel-Aire sitting here and I checked the sender on it. 1.1k ohms cold, but then it's got a Classic Instruments dash and sender in it. It works fine.
I thought this old stuff was supposed to be easy to work on. LOL!
Old 05-21-2013, 08:22 AM   #4
Russell Ashley
Russell Ashley's Avatar
My temp sender came from NAPA and works fine with my 57 guage. The p/n is TS6469SB. It's in the left side head, btw.
Russell Ashley is offline   Reply With Quote
Old 05-21-2013, 11:13 PM   #5
butchp
My thermostat was stuck open gage worked fine,replaced thermostat, gage went full hot. replaced sender gage full hot. remove wire from sender at gage reinstall and gage reads correct. next time I start gage reads full hot, I can put my hand on rad not that hot. I have checked thermostat in a pan of hot water it opens correct. what the heck. NAPA did not have a part number for my truck sender I used one from a 6 cyl a little newer a 1960's. My truck is a 1956 chevy with 235/6.
butchp is offline   Reply With Quote
