Aux battery questions
I want to install the drivers side battery box I purchased. Anyone have pics of a factory one installed? Are any of the bolt holes there? I can install rivnuts if needed? I also have the dual horns, will I have to move them?
I am doing this to put the battery on the stock LS side so I can also install the stock air box for the LS where the original 72 battery box is. Thanks in advance.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
![]() Join Date: Nov 2012
Re: Aux battery questions
I make the aux battery box and harness. AS for mounting only the lower blind nut close to the radiator is there. The other holes will need to be drilled. The second horn that was mounted to the core support next to the radiator will need to move under the tray.
see thread http://67-72chevytrucks.com/vboard/s...d.php?t=555801
Roger Koop |
#3 | |
Roger Koop |
Thanks you sir, that is perfect!!
