Old 05-20-2013, 04:08 PM   #1
dunhamj
shrader valve for air bags.
im interested if any one is running them on their truck. I cant decide if i want to do a static drop or bag it. but the cost of the air management system is really making me think static. I dont need to go up and down, just looking the best stants and ride.
dunhamj is offline   Reply With Quote
Old 05-20-2013, 05:44 PM   #2
northeimcustom
northeimcustom's Avatar
Re: shrader value for air bags.
i am. work good
*^MY BUILD STORY^*
northeimcustom is offline   Reply With Quote
Old 05-20-2013, 05:53 PM   #3
jimmydean
jimmydean's Avatar
You can do manual valves, a single small tank and compressor for pretty damn cheap these days as well. I bagged my '69 with electric valves for less than $800 for everything. You could even go without a compressor and just use a manual fill tank with gauge.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-20-2013, 08:55 PM   #4
dunhamj
so what are manual valves.
Old 05-21-2013, 03:22 AM   #5
andrewmp6
A switch and valve made in to one its old school.Only down side is you have more stuff ran inside the cab.Do you have 600 bucks for a air system ? http://www.azproperformance.com/1-4-...ement-Kit.html Or talk to way2lo2 http://67-72chevytrucks.com/vboard/s...d.php?t=575686
andrewmp6 is offline   Reply With Quote
Old 05-21-2013, 10:50 AM   #6
dunhamj
Re: shrader valve for air bags.
does any one have pics of where they installed their schader valves.
Old 05-23-2013, 07:24 PM   #7
57halfton
I put my shrader valves at the end of my frame rails just under the bed , one on each side for each bag. I set the ride height where I want it and leave it there unless I put something in the bed thats heavy then I adjust the air pressure for the weight.
57halfton is offline   Reply With Quote
