Old 05-20-2013, 04:13 PM   #1
biggsteve97
gear ratio gm 14bolt upgrade
Ok, I have a custom built 87 Chevy heavy half with a mild 3-4 inch lift,np203 t-case, NV4500HD trans, dana 44 open front, locked gm 12 bolt rear with 3.73 gears currently on 32" tires. I have a gm 14 bolt that i have upgraded with disc brakes that I will be installing soon but I am stalled out at the moment. The 14 bolt needs a diff, the open carrier is shot and I am going to put in a locker I just cannot decide whether to upgrade to 4.10 gears or keep the 3.73 gears. I want to put 33" tires on in place of the worn out 32" tires so I know this will change things slightly. I am pushing more than 300hp and 420lb ft of tq out of the built 350V8 so the truck moves great even with a 5000lbs in the bed. I know that the 14 bolt is seriously heavyier than the 12 bolt even with the disc brakes and then throw in taller tires makes me think I should take this opportunity to throw in 4.10s. I built this truck for hauling and so it sees a lot more highway duty than trail duty and sometimes daily driver duty. That depends on the how my daily driver is doing. Any input would be great. I can get the locker and gears used but good here locally from a gears vendor for fairly cheap just dont know how good of an idea it would be to upgrade considering power has never been a problem before.
biggsteve97 is offline   Reply With Quote
Old 05-20-2013, 06:06 PM   #2
b454rat
Re: gear ratio gm 14bolt upgrade
Go with 3.73s if you have the power. 4.10s make the motor scream with those tires at highway speeds. Truck nor you won't even notice the difference between the two axles....
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 05-20-2013, 06:59 PM   #3
biggsteve97
I was kinda leaning that way. The only reason I was thinking of stepping upto the 4.10's besides the fact i could do the locker and gear for $200 is when I use overdrive at 50-55 mph the rpm drops to about 1500 which is just below my cams powerband that starts at 1600. So acceleration and maintaing speed in overdrive below 60 takes alot of throttle. Because of this I have learned not to use overdrive untill speeds of 60 or more. I was thinking that the few hundred rpm increase of the 4.10 might help that but its not a neccessary endeavor.
Old 05-20-2013, 08:24 PM   #4
79Betty
79Betty's Avatar
Keep the 3.73's if u ru upwards of s 35 and bigger then we'll talk 4.10's... Also if u go 4.10's u gotta change the front :/
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 05-20-2013, 08:25 PM   #5
76stepsidechevy
If you didn't have a trans with OD i'd say keep the 3.73. There really isn't a huge difference between 3.73s and 4.10s so If you're going to drop the coin I'd step up to 4.56s or otherwise stick with 3.73 and save the cost of changing the gears in the front to match. If you're anything like me you'll end up going bigger in the future anyways. I started out with 3.73s and 32s with a sm465 (no od) I went to 33s, 35s. and now I'm on 37s and use the granny gear to get the truck moving without wasting the clutch.
76stepsidechevy is offline   Reply With Quote
Old 05-20-2013, 09:06 PM   #6
b454rat
4.10s. I guess I missed the OD part....
Old 05-20-2013, 09:27 PM   #7
LONGHAIR
A NP203 in and 87?
Yeah, go with the lower gears. 1500 rpm is too low for highway speeds.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-20-2013, 10:41 PM   #8
biggsteve97
Originally Posted by LONGHAIR View Post
A NP203 in and 87?
Yeah and mounted on to the back of an nv4500 from a 93 one ton at that. Like i said custom built. I just love the looks on peoples faces when I accomplish something they tell me cant be done. The body and wiring is pretty much the only thing that is left from the 87. I dont think ill ever go to 35's and thats more of a money issue than anything. I dont really want to trim the front fenders to make sure they clear and cannot afford a lift so i think 33's are the biggest this truck will see. So i think the 4.56 gears would be a little overkill for what im doing with the truck. Need to keep it low enough for loading and unloading. As far as the front goes this guy has a loaded carrier with 4.10 gears for about $130. So it will not cost much at all to match the front.
Old 05-23-2013, 06:37 PM   #9
biggsteve97
Ok, after doing some number crunching and some more research I have decided to keep the 3.73 gears for a few reasons, atleast for now. After taking in everyones comments and making a few calculations for tire size and gear ratio as well as looking at tire prices combined with my dana 44 front end's limitations, I have decided that overall I would be better off keeping the 3.73 gears and spending the coin on replacing the front driveshaft that is worn out. For what I do with the truck I have figured out that the majority of 33" tall tires will not handle the weight and abuse I put my truck through and the ones that do are to narrow to fit my wheels. Therefore I would have to either keep the 32's or go upto 35's. Going to a 35 brings up other issues like fitment, I think I would have to trim the fenders since my suspension flexes so much and the 32's almost contact now or I would have to invest in a taller lift which makes it harder to load and unload. Then I'm afraid I may stress the front axle in some situations to where I could break a shaft due to the weight I haul coupled with the power from my engine and my heavy right foot. I do not have the coin to upgrade the front axle to handle that yet. After using the calculation that was given to me by a local 4x4 shop (.12 x tire height) I am just barely outside of what would be best for my application. It was 3.84 and I have 3.73 so Im good. We will see what happens in the future. The wallet sort of won over on this one. If I ever stop using this truck for hauling then I will just turn it into a trail rig and probably go crazy. Thank you all for your input.
