Old 05-20-2013, 04:15 PM   #1
studeystudebaker
studeystudebaker
I have a 78 chevy one ton chasis,rear brakes have been converted to disc---recently the rear locked up,they would release if engine not running,they have the e brake calipers-so I disconnected the e cable ,no difference---so I drove it a few miles with the brakes dragging only the rear,they releasted after setting,next morning I pushed the the little pin in proportional valve-they work ok now ,but not sure what caused it,could it have been that valve--??? don't want this to happen again-- I have been driving it for 6 months--thanks. cab is a 48 load master 5 window,frame 78 one ton-engine 4bt cummins----
studeystudebaker is offline   Reply With Quote
Old 05-20-2013, 09:41 PM   #2
LONGHAIR
Re: studeystudebaker
What master cylinder are you running? One intended for drum brakes would have a residual valve that keeps pressure on the wheels cylinders of the drum system. That helps to prevent a low pedal and gives faster response to the pedal too., but it's bad for disks. Since there are no springs pulling them back from the rotors, they just drag.
In a totally unrelated thing, did you get your name from the pulling truck?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-21-2013, 08:09 AM   #3
studeystudebaker
I had several Studebaker trucks---when I first started with you tube-studeystudebaker50 was all that was available-finally I dropped the 50-I have about 30 videos on you tube-several about the two stroke detroits----on the master cylinder,is there anyway to get the calipers not to drag so tight----to fully release- this is my first experience with disc---all my old stuff was drum----I posted several pictures of my truck-----can't find them---where should I be looking
