Old 05-20-2013, 05:46 PM   #1
ryoung415
Speedo issue
I am having a speedo issue where the speedo cable is not getting turned from the gear in the transmission and I want to know how much fluid I can expect to come out when I pull the gear housing out of the tailshaft of a 700r4 tranny, thanks in advance!
ryoung415 is offline   Reply With Quote
Old 05-20-2013, 06:49 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Speedo issue
Enough to warrant a drain pan. Use a real clean one and pull it off. If you tip the truck forward by raising the rear to get under. The amount that comes out will be minimized
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-20-2013, 09:27 PM   #3
ryoung415
Re: Speedo issue
Thanks for the heads up and jacking up the back end. I have another question. Does the speedo cable connect directly to the speedo gear on the tailshaft? I have what looks like something that changes the direction of the output 90 degrees. I don't know what it's called so I can't find another online. I'll pull it off the truck and post some pics tomorrow.
