05-20-2013, 10:54 PM | #1 |
71 to 67-68 hood conversion
so I've been reading up on this on some other threads. but I still don't get how the hood would be longer on the 68 than the 71. the fenders are the same, the cowl is the same.
is the latch different? everything seems to be in the same place. anyone have an explanation?????
'68 C10 Step Side, 250 6cyl, converted long to short, work in progress |
05-20-2013, 11:36 PM | #2 |
Re: 71 to 67-68 hood conversion
Fenders are not the same!
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD. 1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc |
05-20-2013, 11:36 PM | #3 |
Chevy? Fenders, core support, latch, grill, grill bracket, all different.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
05-20-2013, 11:44 PM | #4 | |
core support, ok. grill and grill bracket, of course. latch, ok. Fender?? what is different??
'68 C10 Step Side, 250 6cyl, converted long to short, work in progress Last edited by jhyder408; 05-20-2013 at 11:51 PM. |
05-20-2013, 11:45 PM | #5 |
a buddies 71 GMC
what is different about the fenders??
'68 C10 Step Side, 250 6cyl, converted long to short, work in progress Last edited by jhyder408; 05-20-2013 at 11:52 PM. |
05-20-2013, 11:51 PM | #6 |
The leading edge Of the fenders for grill surround which aligns with the hood is different
05-20-2013, 11:54 PM | #7 |
Ok, thank you!! umm even for a 71 GMC?
05-20-2013, 11:58 PM | #8 |
yes even for the gmc
05-20-2013, 11:59 PM | #9 |
well dont hold me to that answer i beilieve i read that 68 chevy fenders work as gmc fenders but dont get me lying
05-21-2013, 12:01 AM | #10 |
Alright, thank you all for the quick replies!! Well I definitely learned some new info today, from the experts!! I guess I need to get out of my 67-68 shell more! Thank you again fellas!
05-21-2013, 12:53 AM | #11 |
Proprietor of Dale's Corner
67-68 chevy fenders fit chevy 67- 68 but fit GMC 67-72. So to convert a 69 -72 to a 67-68 you need complete clip ie fenders, rad support and hood
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
05-21-2013, 01:01 AM | #12 | |
SO, to put on a 67-68 chevy hood on a 71 GMC, i really just need the core support out of the 67-68 because the fenders are the same? did i get that right? The goal here is to put a 1967 or 68 hood on a 1971 GMC. He wants the slope nose.
05-21-2013, 03:51 AM | #13 |
All the GMC fenders are the same, you need a hood, a hood latch and a trim piece for the top of the grill, and I'm not even certain you really need the hood latch. First pick is a painted 67 grill (slant nose) and a chrome 70 grill (blunt nose) notice the difference in the size of the trim piece on the tops of the grills. The trim pieces are riveted onto the grill. The 70 (and all 69-72 GMCs) use that big chunky trim piece to "add" the extra length to the blunt nose, mimicking a longer hood, the 67-68s simply fill the gap from the top of the grill to the bottom of the hood. The 2nd pic is a 67-68 cowl hood on a '70 Jimmy with the original hood on the roof.
Also note the 67-70 GMC grills are all the same, except for the "GMC" embossing on the 67, the 71-72 grills have the painted recess. I do not know for sure if the 67-68 trim piece will fit those grills. |
05-21-2013, 07:40 AM | #14 |
The hood latches interchange an all GMCs. There's 67/68 and 69-72. The 67/68s have a sloped front just like the hood,but a '69-up still works.
In '68 when the hoods went more blunt the overall length got shorter. On both Chevys and GMCs a grille surround was used to compensate. On GMC the surround is 3pc...fenders and hood. The fender surround pcs. slip over the same fender. The center pc is what makes up the difference in length for the shorter hood and fills between the grille and hood. In 67/68 there was a body piece used between the grille and hood.
09-07-2014, 11:27 PM | #15 |
Proud owner of a 55.1 AD
Sorry to bring this to the top again, but has anyone else had any experience in putting a 67-68 hood on a 69-72 GMC?
From what I gather from the posts above you can directly put a 67-68 hood on a 69-72 GMC by basically just removing the division bar above the grill. The 69-72 GMC latch will work for a 67-68 hood. Does this sound correct? Thank you, Bob |
09-08-2014, 12:20 AM | #16 |
Awesome information.
09-08-2014, 05:18 AM | #17 | |
What I posted last week when this question was asked in the Blazer/Jimmy section:
