05-20-2013, 11:53 PM | #1 |
vin number decoder
Can anyone help me find a way to decode the vin on a 1965 suburban. Any help would be apreciated.. Thanks.
05-21-2013, 12:19 AM | #2 |
Re: vin number decoder
What is it?
05-21-2013, 11:00 AM | #3 |
If you type 1960-1966 vin decoder into the search you can get all the information you need.
05-21-2013, 11:08 AM | #4 |
c146 6z108123 is the vin.
05-22-2013, 03:33 PM | #5 |
According to the vin number you posted it will be a 66 not a 65.
c-2wd 1-1/2 ton 4-115 wheel base 6-suburban 6-year z-fremont (where assembled) 108123-8,123rd built |
05-23-2013, 09:33 PM | #6 |
its titled as a 1965 but it must be wrong. Thanks guys!
09-27-2013, 11:20 PM | #7 |
is there a different decoder for panels/subs vs PU's? If I plug my vin into the one for PU's it tells me I have a 1/2 ton PU but I have a 1 ton panel?
09-28-2013, 12:23 AM | #8 | |
1961 crewcab
they are pretty straightforward to decipher, and there is not a different set of #'s for subs and panels, they read just like the truck vin, and the 4th digit will show if it is a sub or panel, or truck... check out the thread "where is my 60-66 vin number" for more info- there should be a link in the faq.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
09-28-2013, 12:26 AM | #9 |
1961 crewcab
the new 66's were available in the fall of 65, and 8k is a lower production #, so yours might have been sold and titled in 65 eventhough it was a 66... does it have the brown dash, and different steering wheel?
09-28-2013, 02:25 AM | #10 | |
Is it possible to put a 1 ton (10 foot cargo area) panel body onto a long wheel base c10 PU frame? Maybe the frame got swapped somewhere in the past? 0C154L111572 Now if I read that right it's 1960 2wd 1/2 ton long wheelbase PU Los Angles Plant serial 111572 Last edited by spacedebris; 09-28-2013 at 02:34 AM. |
