Old 05-21-2013, 04:14 AM   #1
lolo33
lolo33's Avatar
electrical issue
Hi all,
got a problem with electricity : after changing my battery which was over, I controlled level of charge = more than 18V - i thought it was an issue with regulator ==> so I changed the regulator (LMC part 36-2520), drove my PU and after 3 or 4 runs : battery flat !
So verified level of charge = 12V. decided to change the alternator (LMC part 36-2760-Z external regulator). verified the level of charge = 12V !
what could be the problem with please ?
thanks for your answers
'70 C10 shortbed - 350 Edelbrock equipped - 4/1 headers - 3" flowmaster exausts
'07 MUSTANG V8 convertible - CAI Spectre - Brembo's - 3" flowmaster exhausts
lolo33 is offline   Reply With Quote
Old 05-21-2013, 08:42 AM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: electrical issue
get a volt/ohm meter and make sure you're getting power to alt, ohm check voltage reg harness. But my bet is the voltage reg, go to parts store and get one. There is no need to use LMC for these service parts
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-21-2013, 10:36 AM   #3
Shyguy
Junior Member
Shyguy's Avatar
When the truck is running the voltage should be in the 13.5-14.5 range.
It is real difficult to work on electrical issues without a volt ohm meter.
Like Dale said, the parts you bought at LMC are available at most auto parts stores. I try to buy everything I can locally, easier to return and I get to compare parts.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-21-2013, 12:34 PM   #4
lolo33
lolo33's Avatar
Sorry, but from France, LMC parts, Eckler's or Classic industries are my possibilities. No parts in france for C10 :-(
Old 05-21-2013, 12:53 PM   #5
Ol Blue K20
Sorry didn't notice that on my little phone screen dang foreign cars with no parts availability! but on a serious note a quick check on the wiring. But since it was overcharging and quit charging when you changed the voltage reg. that's where my vote for the problem is. That voltage reg is not exclusive to the truck so I might check parts stores there just for grins!
Dale
Old 05-21-2013, 01:08 PM   #6
lolo33
lolo33's Avatar
I know that "standard" charge is +/- 14V when engine is running. So THAT'S the problem : with my volt/ohm meter only 12V (check on battery plugs and alternator plugs = same voltage = 12V)
what kind of pb with wiring ?
laurent
Old 05-21-2013, 01:15 PM   #7
Ol Blue K20
First and foremost is make sure there is 12v on the back of alt. second you're just checking continuity and making sure you don't have excessive resistence. I'm not sure how to do links on here but do a search there's downloadable service manuals for each year, that will have wiring schematics. They will also be invaluable to you as there will be step by step diagnostic procedure for you.
Dale
Old 05-22-2013, 12:48 PM   #8
lolo33
lolo33's Avatar
thanks for answers, even I don't have a good understanding sometimes;
today bought a new amp/volt meter in order to check better. if I don't find the issue, will go to my specialist...
Old 05-22-2013, 12:54 PM   #9
Ol Blue K20
I still think the most likely thing will be voltage reg....
Dale
Old 05-22-2013, 02:13 PM   #10
lolo33
lolo33's Avatar
you're probably right, but it's a new one !
Old 05-22-2013, 04:03 PM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Did you make sure the regulator was grounded to the core support? It is mounted on some rubber grommets called wells plugs and a separate wire needs to be run from the regulator body to the core support. I is also supposed to be grounded to the alternator as well, but if the alternator is grounded to the block and the block is grounded to the negative battery cable then it should work just fine.
If you could upgrade to an internal regulated alternator you would be able to get more power and reliability. If you don't get the alternator charging and want to convert then start a thread in the electrical section and we'll show you how easy it is.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-28-2013, 03:46 AM   #12
lolo33
lolo33's Avatar
yesterday, I bought a new electronic multimeter... and it works.
voltage at 750rpm = 12,4V
voltage at 1500rpm = +/- 13V and grows up
other change, after engine running, truck start's at first turn key !
Now I can drive my C10
Old 05-28-2013, 08:39 AM   #13
Ol Blue K20
Good , glad you figured it out
Dale
Old 05-28-2013, 09:05 AM   #14
lolo33
lolo33's Avatar
in fact, I'm not sure that my old alternator was over.
The Multi meter I had was an old one, and not sure that indications it gave were right !
So I am going to keep it (alternator) in case...
Thanks for all your help
