Dropped the 78 shock question
Just put the 78 to a less nose bleed height. Love the way it turned out. Also love the $250 price for the brand new never installed lowering kit. Problem I'm having is shocks. Does anyone know a stock shock maybe off some other car or truck that would work. That I could go pick up at the local Napa. Really want to put some miles on it this weekend.
Re: Dropped the 78 shock question
Chevrolet Cheyenne K2500HD 1992.350tbi.4L80E. GMC Sierra Custom C1500 1983. Oldsmobile Dynamic 88 -65. Volvo V70 -02 and BMW 523i T -99. Harley FXDF -08 and Harley FXDB -10. Honda Dirtbike Dominator -97 and a couple of tractors. |
It followed me home?
Your stock front shocks should be fine, I've used front stockers in the rear and worked just fine.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
I don't know the number off the top of my head but if you go to the Monroe web site they have a complete listing of all their shocks by length and mounting and part numbers.
Wouldn't take you long to find a shorter shock with the correct mounting. Posted via Mobile Device
Having shock extenders in the rear and monroe sensa tracks or bilstien shocks are a solid way to go. Up front some sensa track or kyb gas shocks will work fine.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
the vans from the same years used a 1" shorter shock. they will let the axle hit the frame
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
but shock extenders are a good idea. lets you use stock shocks so you have far more options for shocks and the correct the angle
Thanks for the info guys.
http://www.azproperformance.com/Port...63-87-C10.html
front shock relocating brackets should help you out in the front.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
#10 | |
